ONE WAY PROBLEM WITH IPSEC VPN
veltech
Hi All,
We posted this problem on this forum previously but still do not have a resolution to the problem despite all the excellent suggestions, so hopefully we will find the solution this time around.
We are currently experiencing a problem on an IP SEC VPN tunnel that has all of us here completely stumped. We are hoping that one of you experts out there will be able to assist. Here are some basic details:
NETWORKS
An IPSEC site to site tunnel has been built between the two sites on different networks.
PIX 515E - MAIN SITE
Network 172.16.0.0/24
CISCO 1841 - REMOTE SITE
Network 172.16.99.0/24
ISSUE
All traffic flows over the VPN from the 172.16.99.0 network in the direction of the Pix without problem, such as RDP, SIP etc. Pings will go in both directions across the tunnel. Other than the pings most traffic will NOT flow over the tunnel from the 172.16.0.0 network on the Pix to the 172.16.99.0 network on the 1841. It would appear that something on the 1841 is blocking traffic coming in over the tunnel from the 172.16.0.0 network as we can not get a wireshark capture on a PC on the 172.16.99.0 network, other than the ICMP traces. Usually this is an access list problem but we have checked and double checked the configuration and can't see anything.
TROUBLESHOOTING SO FAR
1. Have tried inserting various access list changes to the tunnel on the 1841 to make specific reference to the 172.16.0.0 network.
2. Have tried various NAT entries.
3. Have removed and then recreated the VPN tunnel from a fresh start.
4. Have made the MTU 1400 on the inside interfaces on the Pix and the 1841.
The tunnel is fully up at all times and as we say can ping in both directions.
Any help would be great.
24 Replies 24
Jennifer Halim
Can you pls share the configuration from both sides.
Do you have any interface access-list applied on the PIX that might be preventing the outbound access to those remote LAN?
Also, on the router, do you have any ACL that might be preventing inbound access as well from the PIX subnet?
Hi Jennifer,
Here are the configs which we have edited a little to reduce the size and removed sensitive information.
We do not have any ACLs blocking the traffic on Pix or 1841 as far as we know. Pings work in both directions, but no other data will flow from Pix to 1841.
Thanks for your help with this one.
PIX CONFIG
Pix# sh run
: Saved
PIX Version 8.0(4)
hostname Pix
domain-name Pix.net
names
interface Ethernet0
nameif Outside
security-level 0
ip address pppoe setroute
interface Ethernet1
nameif Inside
security-level 100
ip address 172.16.0.222 255.255.255.0
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
ftp mode passive
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
dns server-group DefaultDNS
domain-name Pix.net
same-security-traffic permit intra-interface
object-group service support_tcp tcp
port-object eq ssh
access-list Inside_In extended permit ip 172.16.0.0 255.255.255.0 any
access-list XXXXXX_splitTunnelAcl standard permit 172.16.0.0 255.255.255.0
access-list Inside_nat0_outbound extended permit ip 172.16.0.0 255.255.255.0 192.168.27.0 255.255.255.224
access-list Inside_nat0_outbound extended permit ip 172.16.0.0 255.255.255.0 172.16.23.0 255.255.255.0
access-list Inside_nat0_outbound extended permit ip 172.16.0.0 255.255.255.0 192.168.111.0 255.255.255.0
access-list Inside_nat0_outbound extended permit ip 172.16.0.0 255.255.255.0 192.168.12.0 255.255.255.224
access-list Inside_nat0_outbound extended permit ip 172.16.0.0 255.255.255.0 172.16.99.0 255.255.255.0
access-list Outside_1_cryptomap extended permit ip 172.16.0.0 255.255.255.0 172.16.23.0 255.255.255.0
access-list Outside_2_cryptomap extended permit ip 172.16.0.0 255.255.255.0 192.168.111.0 255.255.255.0
access-list Outside_3_cryptomap extended permit ip 172.16.0.0 255.255.255.0 172.16.99.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu Outside 1492
mtu Inside 1492
ip local pool RVPN_POOL1 192.168.27.10-192.168.27.20 mask 255.255.255.0
ip local pool RVPN_POOL2 192.168.12.10-192.168.12.20 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp deny any echo Outside
icmp permit any echo-reply Outside
asdm image flash:/asdm-615.bin
no asdm history enable
arp timeout 14400
nat-control
global (Outside) 101 interface
nat (Outside) 101 192.168.12.0 255.255.255.0
nat (Inside) 0 access-list Inside_nat0_outbound
nat (Inside) 101 0.0.0.0 0.0.0.0
access-group Outside_In in interface Outside
access-group Inside_In in interface Inside
dynamic-access-policy-record DfltAccessPolicy
aaa authentication enable console LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
http server enable
http 172.16.23.0 255.255.255.0 Inside
http 172.16.0.0 255.255.255.0 Inside
http 192.168.12.0 255.255.255.0 Inside
http 192.168.27.0 255.255.255.0 Inside
http 172.16.99.0 255.255.255.0 Inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association lifetime seconds 28800
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association lifetime kilobytes 4608000
crypto dynamic-map RVPN02_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map RVPN02_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map RVPN02_CRYPTO_MAP 65535 set security-association lifetime seconds 28800
crypto dynamic-map RVPN02_CRYPTO_MAP 65535 set security-association lifetime kilobytes 4608000
crypto map Outside_map 1 match address Outside_1_cryptomap
crypto map Outside_map 1 set pfs
crypto map Outside_map 1 set peer XX.XX.XX.XX
crypto map Outside_map 1 set transform-set ESP-3DES-SHA
crypto map Outside_map 1 set security-association lifetime seconds 28800
crypto map Outside_map 1 set security-association lifetime kilobytes 4608000
crypto map Outside_map 2 match address Outside_2_cryptomap
crypto map Outside_map 2 set pfs
crypto map Outside_map 2 set peer XX.XX.XX.XX
crypto map Outside_map 2 set transform-set ESP-3DES-SHA
crypto map Outside_map 2 set security-association lifetime seconds 28800
crypto map Outside_map 2 set security-association lifetime kilobytes 4608000
crypto map Outside_map 3 match address Outside_3_cryptomap
crypto map Outside_map 3 set pfs
crypto map Outside_map 3 set peer <>
crypto map Outside_map 3 set transform-set ESP-3DES-SHA
crypto map Outside_map 3 set security-association lifetime seconds 28800
crypto map Outside_map 3 set security-association lifetime kilobytes 4608000
crypto map Outside_map 65535 ipsec-isakmp dynamic RVPN02_CRYPTO_MAP
crypto map Outside_map interface Outside
crypto isakmp enable Outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 172.16.0.0 255.255.255.0 Inside
telnet timeout 20
ssh 0.0.0.0 0.0.0.0 Outside
ssh 172.16.0.0 255.255.255.0 Inside
ssh 192.168.27.0 255.255.255.224 Inside
ssh 172.16.23.0 255.255.255.0 Inside
ssh 192.168.12.0 255.255.255.0 Inside
ssh timeout 20
console timeout 0
management-access Inside
vpdn group XXXXXXX request dialout pppoe
vpdn group XXXXXXX localname XXXXXXXXXX
vpdn group XXXXXXX ppp authentication chap
vpdn username XXXXXXXXX password XXXXXXXX store-local
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 192.53.103.104
tftp-server Inside 172.16.0.152 C:\TFTP-Root
group-policy XXXXXXX internal
group-policy XXXXXXX attributes
wins-server value 172.16.0.1
dns-server value 172.16.0.1
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelall
default-domain value XXXXXXX
group-policy XXXXXX internal
group-policy XXXXXX attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value XXXXX_splitTunnelAcl
username XXXXX password XXXXXX encrypted privilege 15
tunnel-group XXXXXX type remote-access
tunnel-group XXXXXX general-attributes
address-pool RVPN_POOL1
default-group-policy XXXXXX
tunnel-group XXXXXX ipsec-attributes
pre-shared-key
tunnel-group XX.XX.XX.XX type ipsec-l2l
tunnel-group XX.XX.XX.XX ipsec-attributes
pre-shared-key
tunnel-group <> type ipsec-l2l
tunnel-group  <> ipsec-attributes
pre-shared-key
tunnel-group XXXXXXXX type remote-access
tunnel-group XXXXXXXX general-attributes
address-pool RVPN_POOL2
default-group-policy XXXXXXX
tunnel-group XXXXXXX ipsec-attributes
pre-shared-key
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect http
  inspect ctiqbe
  inspect icmp
service-policy global_policy global
prompt hostname context
Cryptochecksum:
: end
CONFIG OF 1841
1841#sh run
Building configuration...
Current configuration : 8662 bytes
version 12.4
hostname 1841
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging buffered
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authentication login ciscocp_vpn_xauth_ml_2 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa authorization network ciscocp_vpn_group_ml_2 local
aaa session-id common
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 3600
ip inspect name myfw udp timeout 15
ip inspect name myfw h323 timeout 3600
ip inspect name myfw sip
ip inspect name myfw icmp
ip inspect name myfw tcp timeout 3600
ip inspect name myfw http timeout 3600
no ipv6 cef
vpdn enable
archive
log config
  hidekeys
encr 3des
group 2
crypto isakmp key XXXXXXX address <>
crypto isakmp client configuration group XXXXXXX
key XXXXXXXXXXX
dns 208.67.220.220 208.67.222.222
pool SDM_POOL_1
max-users 3
netmask 255.255.255.0
crypto isakmp profile ciscocp-ike-profile-1
   match identity group XXXXXXXX
   client authentication list ciscocp_vpn_xauth_ml_2
   isakmp authorization list ciscocp_vpn_group_ml_2
   client configuration address respond
   virtual-template 2
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
set isakmp-profile ciscocp-ike-profile-1
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to <>
set peer <>
set transform-set ESP-3DES-SHA1
set pfs group2
match address 100
crypto ctcp
interface FastEthernet0/0
description ISP
ip address dhcp
ip access-group Internet-In in
ip nat outside
ip inspect myfw out
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.16.99.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Virtual-Template2 type tunnel
ip unnumbered FastEthernet0/0
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
ip local pool SDM_POOL_1 192.168.27.10 192.168.27.20
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
ip http authentication local
ip http secure-server
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/0 overload
ip nat inside source route-map SDM_RMAP_2 interface FastEthernet0/0 overload
ip access-list extended Internet-In
permit tcp host <> any
permit udp host <> any
permit tcp any any established
permit udp any any eq bootps
permit udp any any eq bootpc
permit udp any eq domain any
permit esp any any
permit udp any any eq isakmp
permit gre any any
permit udp any any eq domain
permit tcp any any eq domain
permit udp host 192.53.103.104 eq ntp any eq ntp
permit icmp any any echo-reply
permit icmp any any time-exceeded
access-list 1 remark CCP_ACL Category=16
access-list 1 permit 172.16.0.0 0.0.0.255
access-list 10 remark CCP_ACL Category=16
access-list 10 permit 172.16.99.0 0.0.0.255
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 172.16.99.0 0.0.0.255 172.16.0.0 0.0.0.255
access-list 100 permit ip 172.16.0.0 0.0.0.255 172.16.99.0 0.0.0.255
access-list 101 remark CCP_ACL Category=2
access-list 101 deny   ip 172.16.0.0 0.0.0.255 172.16.99.0 0.0.0.255
access-list 101 remark IPSec Rule
access-list 101 deny   ip 172.16.99.0 0.0.0.255 172.16.0.0 0.0.0.255
access-list 101 permit ip 172.16.0.0 0.0.0.255 any
access-list 102 remark CCP_ACL Category=2
access-list 102 deny   ip 172.16.0.0 0.0.0.255 172.16.99.0 0.0.0.255
access-list 102 remark IPSec Rule
access-list 102 deny   ip 172.16.99.0 0.0.0.255 172.16.0.0 0.0.0.255
access-list 102 permit ip 172.16.99.0 0.0.0.255 any
route-map SDM_RMAP_1 permit 1
match ip address 101
route-map SDM_RMAP_2 permit 1
match ip address 102
control-plane
transport input all
scheduler allocate 20000 1000
end
Any chance to make below changes and give a try. Also try by removing "ip inspect myfw out"
and "ip access-group Internet-In in" from the fastethernet0/0 of router.Dont forget to put back the commands after testing.
no ip nat inside source route-map SDM_RMAP_2 interface FastEthernet0/0 overload
no access-list 101
access-list 101 permit ip 172.16.99.0 0.0.0.255 any
With Regards,
Safwan
Don't forget to rate helpful posts
The PIX inside_in ACL that you listed above only have the permit statement. Just double checking that there is no "deny" statement above that permit statement that might be blocking the traffic, right?
Also, the inside host that you are testing from, just confirming again that the subnet mask is 255.255.255.0 not 255.255.0.0.
Where is the traffic failing? Are you able to test telnet on a specific port, and run packet capture on the PIX and see if there is anything hitting the PIX.
Hi All,
Thank you for the input again, here are our answers to the various questions raised.
We tried removing the ip inspect myfw and the access group, no luck.
There are no deny statements on either the Pix or the 1841. The subnet mask in both networks is 255.255.255.0
The traffic is failing inbound to the 1841. Traffic flowing into the Pix is all fine. For example we can not run an RDP session inbound to 172.16.99.0/24 network on the 1841 or get a SIP client to register from a remote network over the VPN. As we have said all traffic flows fine inbound to the Pix.
Telnet and SSH will work over the VPN to the 1841 on the 172.16.99.0/24 network, which shows some traffic is getting accross the VPN, as are the pings we are sending. We have opened up the ports for RDP and SIP on the 1841 so dont think the issue is with the ACLs.
Any further thoughts?
I'd recommend following safus advice and removing the int acl in. The acl identifies that potentially sysopt is not enabled and will also help to debug the underlying connection.
Best Regards
Ju
Have you enabled logging on both devices?
Enable logging to a debugging level locally or to a remote syslog server and check the output when you ping successfully and when you try an RDP session.
The logs might give an indication of why the flow is failing.
Just to go back to your MTU settings
I can't see from your 1841 config where you have set the MTU to 1400?
To be sure i'd configure ip tcp-adjust mss 1360 on Fa0/1 and ip mtu 1400 on Fa0/0
Can you also check your default system options on your Pix
sh run all | i sysopt
Make sure it's set to the default MSS of 1380
Hi Scott,
We have run a number of debug sessions and found nothing. We also set MTUs to the lower values on both the 1841 and the Pix. Just to clarify it is traffic in the direction of the 1841 that is causing the issue. All traffic to the Pix is fine.
Anymore suggestions???
Looks like you have a tough problem.
There is one more thing to try.
Some applications use the DF bit on the packet what means, "Don't Fragment"
It tells whatever device is routing the traffic that this packet can't be fragmented. So If the router, (ASA, etc) get's the packet, it has the DF bit=1 and the packet can't "fit" on the next network segment the device drops the packet.
The solution for that on vpn is using:
crypto ipsec df-bit clear-df [interface]
So if the DF bit = 1, the device will clear it and fragment it regardless the application claim.
Please rate if it help you.
Ps. I didn't look at any of the other configuration, I'm just assuming with all the ppl that already looked it must be something tricky, not trivial.
PIX:
show crypto ipsec sa peer x.x.x.x
     watch the encrypt and decrypt counters
show conn detail long | i 172.16.99.
1841:
this way you can determine whether the packets enter the tunnel and whether they are received from the tunnel on 1841
Hi All,
Thank you all for your input we have tried the various suggestions but still have the issue.
I thought it might be helpful to include the results of the "sh crypto ipsec sa" which we ran on the 1841 whilst trying to run an RDP session over the VPN into the 1841. The Pix is absolutely fine, but the enclosed script taken from the 1841 does show some odd things that might point to an issue, the question is what's the issue..... For example the results seem to show two blocks of test results with the first set showing no packets encap or de encap. I can't remember if that is correct on an ISR but the Pix shows only one set of results which are normal. We have tried a whole range of MTU configs taking into account the IPSEC overhead in the tunnel, but none of these configs solved the problem.
This test was run with an RDP session originated on the Pix network to the 1841 network over the VPN. As can be seen we can see the packets increasing over the VPN suggesting that the RDP packets are making it over the VPN but something strange is happening thereafter.
Any help greatly appreciated.
1841#sh crypto ipsec sa
     PFS (Y/N): N, DH group: none
     PFS (Y/N): Y, DH group: group2
interface: FastEthernet0/0
    Crypto map tag: SDM_CMAP_1, local addr <>
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (172.16.0.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (172.16.99.0/255.255.255.0/0/0)
   current_peer <> port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: <>, remote crypto endpt.: <>
     path mtu 1200, ip mtu 1200, ip mtu idb FastEthernet0/0
     current outbound spi: 0x0(0)
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
   local  ident (addr/mask/prot/port): (172.16.99.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (172.16.0.0/255.255.255.0/0/0)
    #pkts encaps: 32, #pkts encrypt: 32, #pkts digest: 32
    #pkts decaps: 35, #pkts decrypt: 35, #pkts verify: 35
    #send errors 1, #recv errors 0
     current outbound spi: 0x3A3881C5(976781765)
     inbound esp sas:
      spi: 0x12C8B13C(315142460)
        transform: esp-3des esp-sha-hmac ,
        in use settings ={Tunnel, }
        conn id: 2009, flow_id: FPGA:9, sibling_flags 80000046, crypto map: SDM_CMAP_1
        sa timing: remaining key lifetime (k/sec): (4523236/3563)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 2010, flow_id: FPGA:10, sibling_flags 80000046, crypto map: SDM_CMAP_1
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
Looking at your logg above on the same device gets a little confusing as the proxy addresses are normal and then reversed. In review of your PIX I also was not sure what purpose the split-tunneling was defined for.
Output from log:
I'd look at your split tunnel and NAT at both ends..
Best Regards
Ju
The split tunnel is set up on the Pix for a remote VPN used by remote users on mainly iphones. The Pix has two remote VPNs one with hairpining set up. The 1841 logg is confusing and we are also not sure why we are seeing two entries and the addresses as you say are reversed. We also feel this could be a NAT issue but the config for NAT is fairly straight forward and we can't see anything obvious in the config on the 1841.
The 1841 VPN was configured through CCP and this often puts extra config that can make trouble shooting a little harder. We are considering erasing the entire config on the 1841 and starting from the ground up using CLI, but first we will look at the NAT.
regards,
