ONE WAY PROBLEM WITH IPSEC VPN
veltech
Hi All,
We posted this problem on this forum previously but still do not have a resolution to the problem despite all the excellent suggestions, so hopefully we will find the solution this time around.
We are currently experiencing a problem on an IP SEC VPN tunnel that has all of us here completely stumped. We are hoping that one of you experts out there will be able to assist. Here are some basic details:
NETWORKS
An IPSEC site to site tunnel has been built between the two sites on different networks.
PIX 515E - MAIN SITE
Network 172.16.0.0/24
CISCO 1841 - REMOTE SITE
Network 172.16.99.0/24
ISSUE
All traffic flows over the VPN from the 172.16.99.0 network in the direction of the Pix without problem, such as RDP, SIP etc. Pings will go in both directions across the tunnel. Other than the pings most traffic will NOT flow over the tunnel from the 172.16.0.0 network on the Pix to the 172.16.99.0 network on the 1841. It would appear that something on the 1841 is blocking traffic coming in over the tunnel from the 172.16.0.0 network as we can not get a wireshark capture on a PC on the 172.16.99.0 network, other than the ICMP traces. Usually this is an access list problem but we have checked and double checked the configuration and can't see anything.
TROUBLESHOOTING SO FAR
1. Have tried inserting various access list changes to the tunnel on the 1841 to make specific reference to the 172.16.0.0 network.
2. Have tried various NAT entries.
3. Have removed and then recreated the VPN tunnel from a fresh start.
4. Have made the MTU 1400 on the inside interfaces on the Pix and the 1841.
The tunnel is fully up at all times and as we say can ping in both directions.
Any help would be great.
24 Replies 24
If your happy to go that far then I would recommend ditching the PIX as they are EOL and upgrading to an ASA. The baby 5505 have some grunt and a recent test that I carried out proved 100Mbps on AES256 with 96Mbps throughput.
However,
Everything happens for a reason and it may be the configuration added by SDM or not. One of the earlier questions I rased was if the remote end could generate the tunnel into the Pix Do you know if this was achieveable ?
In review of your configuration on the 1841 the tunnel is matched against ACL 100
access-list 100 permit ip 172.16.99.0 0.0.0.255 172.16.0.0 0.0.0.255
access-list 100 permit ip 172.16.0.0 0.0.0.255 172.16.99.0 0.0.0.255
You may wish to remove one of those lines..
Kind Regards
Ju
yes, remove that line and switch to another IOS if it does not help
Hi Everyone,
I have spent some time in our Lab over the holiday season and would like to provide an update to this problem in the hope that someone can offer further assistance.
UPDATE
Our troubleshooting has seen us try all sorts of combination of fragmentation settings, access lists, NAT rules, and all the suggestions within this post have been tried in the Lab. We have set up two 1841 routers with the same config, or perhaps I should say mirrored configs, and we have been able to replicate the problem in both directions between router A and router B. So, it is fair to say that the Pix is working as it should and our problem is with the ISR Router configuration. Just to recap; we can ping in both directions, and all Sh Crypto outputs are normal. However, the original problem of not being able to RDP into the ISR routers still exists. Now that we have two 1841s hooked up the problem is in both directions.
Anyone have any further thoughts ???
Can you post your current 1841 configuration ?
Best Regards
Ju
http://helpamunky.wordpress.com/
As requested here is the 1841 latest config, edited for security purposes. This has changed from the original and still pings in both directions over the tunnel, but no RDP..
1841#sh run
Building configuration...
Current configuration : 7175 bytes
! No configuration change since last restart
version 12.4
hostname 1841
boot-start-marker
boot-end-marker
no logging buffered
enable secret XXXXXXXXXXXXXXXX
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
ip cef
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 3600
ip inspect name myfw udp timeout 15
ip inspect name myfw h323 timeout 3600
ip inspect name myfw sip
ip inspect name myfw icmp
ip inspect name myfw tcp timeout 3600
ip inspect name myfw http timeout 3600
no ip domain lookup
vpdn enable
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key XXXXXXXXXX address <>
crypto isakmp nat keepalive 15
crypto ipsec transform-set MYSET esp-3des esp-sha-hmac
crypto map MYMAP 10 ipsec-isakmp
set peer <>
set transform-set MYSET
set pfs group2
match address 100
interface FastEthernet0/0
description ISP
ip address dhcp
ip access-group Internet-In in
ip inspect myfw out
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map MYMAP
interface FastEthernet0/1
ip address 172.16.99.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip route 172.16.0.0 255.255.255.0 <>
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 101 interface FastEthernet0/0 overload
ip access-list extended Internet-In
permit ip 172.16.0.0 0.0.0.255 any
permit udp host <> host <<1841 PUBLIC ADDRESS>> eq isakmp
permit ahp host <> host <<1841 PUBLIC ADDRESS>>
permit esp host <> host <<1841 PUBLIC ADDRESS>>
permit udp host <> host <<1841 PUBLIC ADDRESS>> eq non500-isakmp
permit tcp any any established
permit udp any any eq bootps
permit udp any any eq bootpc
permit udp any eq domain any
permit esp any any
permit udp any any eq isakmp
permit tcp any any eq 600
permit gre any any
permit udp any any eq domain
permit tcp any any eq domain
permit udp host 192.53.103.104 eq ntp any eq ntp
permit tcp any any eq 22
permit tcp any any eq 5900
permit tcp any any range 9001 9009
permit icmp any any echo-reply
permit icmp any any time-exceeded
access-list 100 permit ip 172.16.99.0 0.0.0.255 172.16.0.0 0.0.0.255 log
access-list 101 deny   ip 172.16.99.0 0.0.0.255 172.16.0.0 0.0.0.255
access-list 101 permit ip 172.16.99.0 0.0.0.255 any
control-plane
banner login ^C
line con 0
XXXXXXXXXXX
logging synchronous
line aux 0
line vty 0 4
XXXXXXXXXXXXX
transport input all
scheduler allocate 20000 1000
ntp clock-period 17179485
ntp server 192.53.103.104
webvpn cef
end
three minor recommendations:
Can you remove the route "ip route 172.16.0.0 255.255.255.0 <>" as this should not be required
Run a telnet test on 3389 to a server eg: telnet "ip address" 3389 and see if you get a response. This could indicate an MTU based issue.
Carry out a ping test with the DF bit set and see at what size it gets through..
Ju
veltech
Hi All,
We have now found the cause of the RDP issue over the VPN and I would like to share our results with you to try and help anyone else who finds themself with the same problem.
On the 1841 (remote site) we had set up the following NAT entry to allow RDP access over the Internet to the internal host at 172.16.99.254, which as you will recall from this thread worked OK.
ip nat inside source static tcp 172.16.99.254 9004 interface FastEthernet0/0 9004
This NAT statement seem to conflict with traffic coming into the 172.16.99.0 network over the VPN. 172.16.99.254 is the IP address of the PC we were trying to RDP into over the VPN. As soon as I removed this NAT statement I was able to RDP over the VPN using the 172.16.99.254 address. Still not exactly sure why this would have stopped the VPN traffic but that is now on my to-do-list.
Now we will figure out how to set up the remote access over the WAN.
Thank you to all who assisted.
I would also test it with
  no ip cef
veltech
Hi All,
We have now concluded our Lab work with this problem and fixed all the issues.
RDP was made accessible over the VPN by removing the static NAT entry. RDP was made available over the WAN through the use of a route map configuration. We also found during testing that SIP clients trying to register to a SIP server may also have the issue with the static NAT statement if they are registering over a VPN to main site for example. A combination of static NAT and route maps will fix these issues.
Hope this is usefull and we will now upload this as a document for all to see.
Thanks for sharing the information. This will definitely be useful for others.
