OpenLDAP group Authentication issue with Cisco ASA RAVPN
bheda.laxman
I've configured RA VPN on ASA5520 with OpenLDAP server authentication. It works fine for all the users existed in LDAP database, but my requirement is I want one particular group to be able to access VPN and not all the users. I have checked most of Cisco documents but all are leading to Microsoft's AD and LDAP attribute map creation. Is there any way to achieve the same thing with OpenLDAP server and not with AD?
5 Replies 5
bheda.laxman
Got it working.
Created the LDAP attribute map with memberUid attribute and used it as a Authorization server. No map in Authentication server.
Hi, please could you help me with my part of the configuration? I am trying to achieve the same thing as you did, not only authenticate but also authorize particular users according to their openLDAP groups.
Do you mean that it's necessary to create another aaa-server just only for the authorization?
Here is my configuration
aaa-server OpenLDAPsrv protocol ldap
aaa-server OpenLDAPsrv (outside) host ldap.work.com
server-port 389
ldap-base-dn dc=work,dc=com
ldap-scope subtree
ldap-naming-attribute uid
ldap-login-password ***
ldap-login-dn cn=asa,dc=work,dc=com
server-type openldap
ldap-attribute-map LDAPmapping
ldap attribute-map LDAPmapping
  map-name memberOf Group-Policy
  map-value memberOf cn=vpn_group1,cn=vpn_Users,ou=Groups,dc=work,dc=com LDAPtestGroup1
  map-value memberOf cn=vpn_group2,cn=vpn_Users,ou=Groups,dc=work,dc=com LDAPtestGroup2
group-policy LDAPtestGroup1 internal
group-policy LDAPtestGroup1 attributes
  vpn-tunnel-protocol IPSec l2tp-ipsec
  split-tunnel-policy tunnelspecified
  split-tunnel-network-list value split1
group-policy LDAPtestGroup2 internal
group-policy LDAPtestGroup2 attributes
  split-tunnel-network-list value split2
tunnel-group LDAPtestTunnel type remote-access
tunnel-group LDAPtestTunnel general-attributes
  authentication-server-group OpenLDAPsrv
  authorization-server-group OpenLDAPsrv
  authorization-required
  address-pool remoteaccesspool
  default-group-policy NoAccess
tunnel-group LDAPtestTunnel ipsec-attributes
pre-shared-key ***
group-policy NoAccess internal
group-policy NoAccess attributes
vpn-simultaneous-logins 0
address-pools none
Jozef
Hi Jozef.cmroej,
Yep thats right. Your config looks okay, what you additionally have to do is, create one more aaa-server group with same ip/host and different aaa name. Reference newly created aaa server for authentication and use this (OpenLDAPsrv) for Authorization.
I could send you the working config but it will take 3-4 days as I'm travelling these days.
Let me know if that doesn't work.
-Laxman
Hi Laxman,
thank you for your replay. I added additional LDAP server group for authorization and trying to match LDAP attribute name CN which gives me the name of the LDAP group. Then the ASA matches this attribute to group policy.
But what I would like to achieve is an authorization for an user who is a member of more than one group in the openLDAP server. I would use Dynamic Access Policies where I would define that an user must have all attributes (ldap groups) in order to get an access to the network. But even the LDAP server sends multiple attributes which identify user's LDAP groups, I get just only one user's group first in the alphabet on the ASA.
Example:
vpnuser3 is a member of 2 groups - vpn_group1 and vpn_group2. But in debug I see only one group vpn_group1.
[14595] Session Start
[14595] New request Session, context 0xd862b898, reqType = Authentication
[14595] Fiber started
[14595] Creating LDAP context with uri=ldap://x.x.x.x:390
[14595] Connect to LDAP server: ldap://x.x.x.x:390, status = Successful
[14595] supportedLDAPVersion: value = 3
[14595] Binding as asa
[14595] Performing Simple authentication for asa to x.x.x.x
[14595] LDAP Search:
        Base DN = [OU=Users,DC=work,DC=com]
        Filter  = [uid=vpnuser3]
        Scope   = [SUBTREE]
[14595] User DN = [uid=vpnuser3,ou=servis,ou=Users,dc=work,dc=com]
[14595] Server type for x.x.x.x unknown - no password policy
[14595] Binding as vpnuser3
[14595] Performing Simple authentication for vpnuser3 to x.x.x.x
[14595] Processing LDAP response for user vpnuser3
[14595] Authentication successful for vpnuser3 to x.x.x.x
[14595] Retrieved User Attributes:
[14595]         employeeType: value = Spec
[14595]         sambaPrimaryGroupSID: value = S-1-5-21-2974034282-1106368442-2707221876-513
[14595]         displayName: value = vpnuser3
[14595]         givenName: value = vpnuser3
[14595]         sambaLogonScript: value = logon.cmd
[14595]         objectClass: value = top
[14595]         objectClass: value = person
[14595]         objectClass: value = organizationalPerson
[14595]         objectClass: value = inetOrgPerson
[14595]         objectClass: value = posixAccount
[14595]         objectClass: value = shadowAccount
[14595]         objectClass: value = sambaSamAccount
[14595]         sambaHomeDrive: value = H:
[14595]         sambaLogonTime: value = 0
[14595]         uid: value = vpnuser3
[14595]         mail: value = vpnuser3@work.com
[14595]         uidNumber: value = 3365
[14595]         cn: value = vpnuser3
[14595]         sambaLogoffTime: value = 2147483647
[14595]         sambaPwdLastSet: value = 1326810783
[14595]         loginShell: value = /bin/bash
[14595]         sambaAcctFlags: value = [UX]
[14595]         sambaProfilePath: value = \\hfserver\profiles\vpnuser3
[14595]         gidNumber: value = 513
[14595]         sambaPwdMustChange: value = 2147483647
[14595]         sambaPwdCanChange: value = 0
[14595]         gecos: value = System User
[14595]         sambaSID: value = S-1-5-21-2974034282-1106368442-2707221876-7730
[14595]         homeDirectory: value = /home/users/vpnuser3
[14595]         sambaKickoffTime: value = 2147483647
[14595]         sn: value = vpnuser3
[14595]         sambaHomePath: value = \\hfserver\vpnuser3
[14595] Fiber exit Tx=321 bytes Rx=1115 bytes, status=1
[14595] Session End
[14596] Session Start
[14596] New request Session, context 0xd862b898, reqType = Other
[14596] Fiber started
[14596] Creating LDAP context with uri=ldap://x.x.x.x:390
[14596] Connect to LDAP server: ldap://x.x.x.x:390, status = Successful
[14596] supportedLDAPVersion: value = 3
[14596] Binding as asa
[14596] Performing Simple authentication for asa to x.x.x.x
[14596] LDAP Search:
        Base DN = [OU=Groups,DC=work,DC=com]
        Filter  = [memberUid=vpnuser3]
        Scope   = [SUBTREE]
[14596] User DN = [cn=vpn_group1,ou=Groups,dc=work,dc=com]
        Base DN = [OU=Groups,dc=work,dc=com]
        Scope   = [SUBTREE]
[14596] Retrieved User Attributes:
[14596]         sambaSID: value = S-1-5-21-2974034282-1106368442-2707221876-1007
[14596]         gidNumber: value = 1007
[14596]         memberUid: value = vpnuser3
[14596]         displayName: value = vpn_group1
[14596]         sambaGroupType: value = 2
[14596]         objectClass: value = top
[14596]         objectClass: value = posixGroup
[14596]         objectClass: value = sambaGroupMapping
[14596]         cn: value = vpn_group1
[14596] Fiber exit Tx=333 bytes Rx=2719 bytes, status=1
[14596] Session End
It's possible to match multiple LDAP groups to one DAP on the ASA?
Jozef
Could anyone please post a working config on this please?
