passing IPSEC traffice problem
bigassmonkey
I have a pix 6.3
when I use the Cisco VPN Client software to connect to another companies VPN.....it connects and gets an ip on the inside of there network but it will not pass packets....it works fine out side of the PIX
any Ideas?
gangelozzi
Community Member
i am having the same problem does the pix you are behind have isakmp nat-traversal
