Phase 1 connection 412 error
Stevan44
Level 3
Level 3
RA VPN Phase 1error using ASA5550 and Cisco VPN Client 5.7.440
I can't seem to get past the error 412 “The remote peer is no longer responding”. This message is from the Cisco VPN client log. I can see the VPN ACL on the outside hit count increase so I know that the client is reaching the ASA. But it not talking back. The ASA is in the Single, Router mode to support VPN. I believe that the config is correct at least to my knowledge. I would be most appreciative, if someone would be kind as to find the issue that escape me.
I've added the config . but removed the cert information and most Network objects for the purpose of brevity.
Steve
The issue was missing a NAT (outside,outside) DMZ and Transform-set issue (debugging revealed error All SA proposals found unacceptable and Warning: Ignoring IKE SA (src) without VM bit set). I hope that this will help someone.
Thanks Sheraz for your suggestion, please mark this as solved.
Sheraz.Salim
you configuration look to be fine. here is the link the same error is been discussed and proposed a solution too. have a look at it.
https://community.cisco.com/t5/vpn/vpn-client-reason-412-the-remote-peer-is-no-longer-responding/td-p/917461
please do not forget to rate.
