PIX TO PIX PROBLEM
hassanjavaid
: Saved
PIX Version 7.1(2)
hostname pixfirewall
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address x.x.x.13  255.255.255.248
interface Ethernet1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
access-list 101 extended permit ip host 192.168.2.14 host 172.16.32.1
access-list 101 extended permit ip host 192.168.2.14 host 172.16.32.2
access-list 101 extended permit ip host 192.168.2.14 host 172.16.32.3
access-list nonat extended permit ip host 192.168.2.14 host 172.16.32.1
access-list nonat extended permit ip host 192.168.2.14 host 172.16.32.2
access-list nonat extended permit ip host 192.168.2.14 host 172.16.32.3
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
no asdm history enable
arp timeout 14400
nat (inside) 0 0.0.0.0 0.0.0.0
nat (inside) 0 access-list nonat
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.x.9
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set RMS esp-aes-192 esp-sha-hmac
crypto map My_Transform_Set 1 match address 101
crypto map My_Transform_Set 1 set peer y.y.y.y
crypto map My_Transform_Set 1 set transform-set RMS
crypto map My_Transform_Set interface outside
isakmp enable outside
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption aes-192
isakmp policy 1 hash sha
isakmp policy 1 group 2
isakmp policy 1 lifetime 28800
isakmp policy 65535 authentication pre-share
isakmp policy 65535 encryption 3des
isakmp policy 65535 hash sha
isakmp policy 65535 group 2
isakmp policy 65535 lifetime 86400
tunnel-group y.y.y.y type ipsec-l2l
tunnel-group y.y.y.y ipsec-attributes
pre-shared-key *
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect dns maximum-length 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
Cryptochecksum:6ac9bcc328574fcf4177fc23f53864e0
: end
Is there any problem in this configuration?
Thank You
Jennifer Halim
Please add the following NAT exemption:
access-list nonat permit ip 192.168.2.0 255.255.255.0 172.16.32.0 255.255.255.0
Jennifer Halim
