PIX to PIX using IPSec tunnel and websense issues
naeem.shah
I have a IPSec tunnel running between PIX's 515E (PIX-A) and 506E (PIX-B). The version on the PIX 515E is 6.3(3)and the PIX506E is 6.3(4). The tunnels work perfect but I would like the dhcp client on PIX-B to authenticate for web browsing to my websense server which is running on PIX-A. I have put in the command for I entered the command for on PIX-B as follows:
url-server (inside) vendor websense host 10.X.X.X timeout 5 protocol UDP version 4
filter url http 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 allow
The web traffic seem to be bypass the websense server on PIX-A.
What is the best way to do this?
mchin345
Level 6
Level 6
management-access inside
no url-server (outside) vendor websense host 10.x.x.x timeout 5 protocol TCP version 1
url-server (inside) vendor websense host 10.x.x.x timeout 5 protocol TCP version 1
sysopt connection permit-ipsec
This will allow the PIX to source its websense requests from the inside interface IP, so the public IP won't need to be known.
Couple of questions?
The command that you posted are to be applied on PixB correct? and what does the management-access inside do?
Sincerely,
Naeem
The commands work perfectly for my solution and thank you for the help
