please look at these 2 configs and help with vpn not connecting
jmukavit1
Result of the command: "sh run"
: Saved
ASA Version 8.3(1)
hostname ciscoasa
enable password not shown encrypted
passwd not shown encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.101.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network 4thsteetoffice
subnet 192.168.100.0 255.255.255.0
object network NETWORK_OBJ_192.168.101.0_24
subnet 192.168.101.0 255.255.255.0
object network A_
object network PublicServer_NAT1
host 192.168.101.20
object-group network 4thstreetmainoffice
network-object object 4thsteetoffice
access-list outside_access_in extended permit tcp any host 192.168.101.20
access-list outside_access_in extended permit icmp any any echo
access-list outside_access_in extended permit ip 192.168.101.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list outside_access_in extended permit tcp object 4thsteetoffice 192.168.101.0 255.255.255.0
access-list nonat extended permit ip 192.168.101.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list outside_cryptomap extended permit ip object NETWORK_OBJ_192.168.101.0_24 192.168.100.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_192.168.101.0_24 NETWORK_OBJ_192.168.101.0_24 destination static 4thstreetmainoffice 4thstreetmainoffice
nat (inside,outside) source static NETWORK_OBJ_192.168.101.0_24 NETWORK_OBJ_192.168.101.0_24 destination static 4thsteetoffice 4thsteetoffice
nat (inside,outside) dynamic interface
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.101.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 2 match address outside_cryptomap
crypto map outside_map 2 set peer 64.42.21.170
crypto map outside_map 2 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.101.5-192.168.101.36 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
tunnel-group to_reno4thstreet_office type ipsec-l2l
tunnel-group to_reno4thstreet_office general-attributes
tunnel-group to_reno4thstreet_office ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:fe308825f717695e751ae425304285fb
: end
: Saved
ASA Version 8.3(1)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
object network A_
host 192.168.101.20
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
: end
Jouni Forss
Both configurations list the same LAN netowork 192.168.101.0/24 both in the interface configurations and the L2L VPN configurations.
There is also mention of network 192.168.100.0/24 which is not configured on any interface.
So there is clearly some problems related to the subnets used.
Could you clear up this situation for us?
- Jouni
