problem EASY VPN
Acruzgreg
hello,
i have a problem whit mi easy vpn client is down every 10 seconds an appear this this message in debug:
*Mar 11 08:50:33.557: ISAKMP:(3005):purging node -1308217119
*Mar 11 08:50:41.345: ISAKMP:(3004):purging SA., sa=83A4B344, delme=83A4B344
regards
17 Replies 17
Angel,
What device is acting as the ezvpn server? ASA, router, etc?
Jus out of curiosity let me ask you something.... is any special reason why you're implementing an ezvpn connection instead than a regular site-to-site ipsec tunnel?
Federico.
Federico,
My ezvpn server is one router cisco 2800 and my reason is that in ezvpn client have a router cisco 800 whit adsl and don´t have static ip public
regards
Angel,
If the only reason is because the 800 side does not have a static IP, you can try a dynamic-to-static IPsec tunnel. Take a look:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080093f86.shtml
Anyway, ezvpn should work as well. I'm just wondering if you want to give the above configuration a try and see how does it goes.
Federico.
