09-08-2006 04:50 AM
HI,
I have a router 1841 (C1841-ADVENTERPRISEK9 - Version 12.3(14)T7), and it doesn?t work the call ISDN.
The log is:
Sep 8 12:03:31: ISDN BR0/1/0 EVENT: UserIdle: callid 0x800D received ISDN_CALL (0x0)
.Sep 8 12:03:31: ISDN BR0/1/0 EVENT: process_bri_call: call id 0x800D, called_number 0943577560, Guid E130C496800E speed 64, call type DATA, bchan -1 clng_num none
.Sep 8 12:03:31: ISDN E130C496800E Error: Invalid DSL (0) SERROR: isdn_get_display_text_from_gtd: false ret
.Sep 8 12:03:31: ISDN E130C496800E Error: Invalid DSL (0) Error: Invalid DSL (0) SERROR: isdn_get_mlpp_from_gtd: MLPP from GTD failed
.Sep 8 12:03:31: ISDN BR0/1/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
.Sep 8 12:03:31: ISDN BR0/1/0 EVENT: handle_l2d_srq_mail: Activating Layer 1
.Sep 8 12:03:31: ISDN BR0/1/0 EVENT: isdn_sw_cstate: State = 4, Old State = 4
.Sep 8 12:03:31: ISDN BR0/1/0 EVENT: service_queue_from_physical_layer: Recvd L1 prim ISDN_PH_ACT_IND state is IF_ACTIVATING
.Sep 8 12:03:31: ISDN BR0/1/0 EVENT: service_queue_from_physical_layer: Recvd L1 prim ISDN_MPH_EI2_IND state is IF_ACTIVE
.Sep 8 12:03:32: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 0 changed to up
.Sep 8 12:03:32: ISDN BR0/1/0 EVENT: process_rxstate: ces/callid 1/0x800D calltype 1 HOST_INFORMATION
.Sep 8 12:03:32: ISDN BR0/1/0 EVENT: process_rxstate: ces/callid 1/0x800D calltype 1 HOST_PROCEEDING
.Sep 8 12:03:33: ISDN BR0/1/0 EVENT: process_rxstate: ces/callid 1/0x800D calltype 1 HOST_CONNECT
.Sep 8 12:03:33: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to up
.Sep 8 12:03:33: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 0943577560 N/A
.Sep 8 12:03:34: ISDN BR0/1/0 EVENT: process_rxstate: ces/callid 1/0x800D calltype 1 HOST_DISCONNECT
.Sep 8 12:03:34: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to down
.Sep 8 12:03:34: ISDN BR0/1/0 EVENT: process_rxstate: ces/callid 1/0x800D calltype 1 HOST_DISCONNECT_ACK
.Sep 8 12:03:39: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 0 changed to down
.Sep 8 12:03:39: ISDN BR0/1/0 EVENT: service_queue_from_physical_layer: Recvd L1 prim ISDN_PH_DEACT_IND state is IF_ACTIVE
.Sep 8 12:03:39: ISDN BR0/1/0 EVENT: isdn_sw_cstate: State = 0, Old State = 4
Can anybody help me??
Thank you very much !!!
Best Regards
Nuria
09-08-2006 05:24 AM
Hola,
can you check if your ISDN interface is actually connected to an ISDN and not a regular phone line ? Can you post the configuration of your router ?
GNT
09-09-2006 09:49 AM
I initially agreed that the first several messages look like the ISDN was not working. But these messages I believe indicate that it did work:
I believe that these indicate that the connection did establish - and in less than a second the other end terminated the call.
I believe that it would be helpful to have the output of debug ppp negotiation and of debug ppp authentication.
Rick
