Problem failover ASA 5510 with VPN.
m.freitas
Dear?s,
I?m have um failover with the ASA 5510.The tunnel L2L is working! When the primary goes for shutdown, the secondary one is activated, but i have problems in the VPN. The following error occurs:
Apr 06 15:27:38 [IKEv1]: IP = 172.19.33.7, Removing peer from peer table failed, no match!
Apr 06 15:27:38 [IKEv1]: IP = 172.19.33.7, Error: Unable to remove PeerTblEntry
After a time the VPN it connects. Somebody has a solution for this?
Marcio - Auriga Informatica
p.krane
Level 3
Level 3
First check if your failover is a stateful one, if not change it to stateful. Also check if isakmp commands
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
are configured properly.
My friend! See this new error:
Cannot create dynamic ACL for Backup L2L entry TUNEL_DATACENTERS 20
I use the version 7.2(2)!
Thank you very much!
Marcio - Auriga Informatica.
