Problem in accessing vpn more then one connection
funrakesh
Dear Experts,
i had configure remore vpn in cisco asa 5505(with 10 vpn peer license) it is working fine but the problem is only one remote client(vpn client) can access inside network access other remote vpn can connect  but cant get access to the inside network
Kimberly Adams
Level 3
Level 3
Can you please paste up your configuration and a show version as well?  This will help us to see if there is anything in your configuration that could be causing this.
Kimberly
Thanks and Cheers! Kimberly Please remember to rate helpful posts.
thanx adams for responding my post sir i had found my problem and i correct it also sir.
again thanx for quick response .
Rakesh
