Problem in deploying an IPsec manual tunnel towards a foreign node
reggiani
We're deploying an IPSec tunnel in manual mode (without IKE) between a Cisco router 1751 and an Ericsson remote node.
We've disabled the VPN card (command "no crypto engine accelerator", since that there are several bugs not yet fixed with encryption cards in manual mode).
When the remote node tries to convey packets inside the tunnel towards the router, debugging (crypto engine enabled) shows a message such as "invalid SPI", but the SPI shown in the log message is the same as the SPI configured in the router
a.lysyuk
Hello.
Do you have any NAT devices in the path between Cisco router 1715 and Ericsson remote node?
Unfortunatelly I cannot give you a sure response, since that the remote node is located inside a foreign provider network.
Anyway, the packet comes from internet towards the 1751, and by means of a sniffer I've checked that:
-the source IP address of the packet is the same as the one configured as the remote peer in the configuration of the router for that crypto map
-the destination IP address of the packet is the same as the one configured as ip address on the public interface of the 1751 (where there is the crypto map applied)
-the ESP encapsulation (protocol number 50) of the incoming packet is correct
-the incoming SPI is the same as the one configured in the router for that crypto map
in spite of that, the debugging message shows all parameters correct, but also SPI invalid
bye, Andrea
mnaveen
If the received IPSec packet specifies SPI that does not exist in SADB. This may be a temporary condition due to slight differences in aging of SAs between the IPSec peers, or it may be because the local SAs have been cleared. It may also be because of incorrect packets sent by the IPSec peer. This may also be an attack.
The proposed action
The peer may not acknowledge that the local SAs have been cleared. If a new connection is established from the local router, the two peers may then reestablish successfully. Otherwise, if the problem occurs for more than a brief period, either attempt to establish a new connection or contact the peer's administrator.
Naveen
mnaveen@cisco.com
The mode of IPsec is manual, so lifetime of SAs is infinite.
Anyway, a new bug ID has been created for this problem, the code is CSCea69097.
In the bug descritpion there is a workaround explained, but at the moment that doesn't work yet......
