Problem in LNS router caused system to get down !!!!
Dr.X
Level 2
Level 2
hi ,
i have myem system with the topology  of ADSL ,  im as just an  ISP .
http://www.rracuares.com/wp-content/uploads/2010/07/PPPoE-over-L2TP.png
all my access is only on LNS router ,
in my LNS router , im configuring the AAA with radius server ,
actually i have two LNS router , and have load balancing from PSTN LAC to my LNS routers .
yesterday ,
on radius server , i cleared all the users which was on LNS1 , and cleared all users that were on router LNS1 ,
the problem appeared , when the users  agian come to the LNS ,
the problem was , alot of users  get a state of ""never "" when i type
#sh users  !!!!!!!!!!!!!!
here is a sample of output command :
as u see, alot of users didnt get an ip from router pool , and the pool has alot of free ips , but some users fall in the state "never " ===>look at the last coloum
LNS1#sh users | i never
  Vi145        xxxxxx8@netg PPPoVPDN    never
  Vi224        xxxxxx8@netg PPPoVPDN     never
  Vi290        xxxxxx11@netg PPPoVPDN    never
  Vi469        xxxxxxx03@netg PPPoVPDN  never
  Vi635        xxxxxxxx42@netg PPPoVPD   never
  Vi718        xxxxxx860@netg PPPoVPDN   never
  Vi1501       xxxxxxx54@netg PPPoVPDN   never
  Vi1543       xxx494@netg PPPoVPDN      never
  Vi1749       xxxxxx0742@netg PPPoVPDN  never
  Vi1807       xxxx4194@netg PPPoVPDN    never
  Vi2093       xxxxxx894@netg PPPoVPDN  never
  Vi2158       xxxxxx5258@netg PPPoVPDN  never
  Vi2211       xxx2524@netg PPPoVPDN     never
  Vi2244       xxxx295@netg PPPoVPDN     never
  Vi2416       xxx663@netgPPPoVPDN      never
  Vi2606       xxxx49@netg PPPoVPDN      never
  Vi2697       xxxx952@netg PPPoVPDN     never
  Vi2994       xxxxx03@netg PPPoVPDN     never
  Vi3216       xx7816@netg PPPoVPDN      never
  Vi3324       xxxx293@neg PPPoVPDN     never
  Vi3385       xx8036@netg PPPoVPDN      never
this problem got alot of time , and finally  i got my router reload  and ofcourse my system got down !!!!!
my question is , what is the reason of this problem ???????
why the problem solved when i reloaded the  LNS router ????
wish to help so as not to fall in the same problem
i will include the sample of my LNS brief config that delas with  virtual template interface :
interface Virtual-Template1
ip unnumbered GigabitEthernet0/1
ip tcp adjust-mss 1480
no logging event link-status
peer default ip address pool p1 p2
ppp mtu adaptive
ppp authentication pap vpdn
ppp authorization vpdn
ppp accounting vpdn
regards
Ahmad
Wajdi MEJRI
I have this problem too on Cisco ASR 1006 LNS router.
but problem is solved tanks to OTBS and CNTE.
i just add this commands:
radius server radauth
aaa group server radius radauth
server x.x.x.x auth-port 1812 acct-port 1813
server y.y.y.y auth-port 1812 acct-port 1813
authorization reply reject prohibited-attribute
deadtime 2
radius-server attribute list prohibited-attribute
attribute 13
the problem occurs when sending RADIUS attribute 13 (Framed-Compression)
so LNS should reject this attribute specified in the list prohibited-attribute for Access-Reply
hi ,
sounds complex issue
thanks alot very much for your reply ,
im really appreciating your help ,
i will try it and give you a reply with the result ,
with my best regards
