Problem to reach a subnet through Cisco VPN client
Good morning,
I configured a remote VPN in order to reach a subnet specific of my company, I connect across of Cisco VPN client. We suppose that this subnet has 2 IPs availables(10.10.10.2 and 10.10.10.3), when I connect to that subnet, sometimes I can do ping to the first address but the second no and then, I connect again to the VPN and the opposite occurs, the first IP can´t do ping but to the second IP yes. Sometimes I can do ping to all IPs of the subnet. This Subnet is inside of a VRF
Best regards,
Hello, Francisco.
Could you please share your configuration?
Are you sure that IP-addresses you are trying to ping are really on the subnet (you might be pinging some other devices with the same IP-addresses)?!
This is de configuration:
aaa new-model
aaa group server radius Radius-PMS
server-private X.X.X.X auth-port 1812 acct-port 1813 key 70055415550
server-private X.X.X.X auth-port 1812 acct-port 1813 key 7  06575D7218
ip radius source-interface Loopback0
aaa authentication login default local
aaa authentication login vpn1 local
username xxxx privilege 15 secret 5 xxxxxxxxxxxxxxxx
crypto isakmp client configuration group VPN_VOIP
key xxxxxx
pool VPN_VOIP
acl VPN_VOIP
crypto isakmp profile VPN_VOIP
   vrf VPN_xxxxxxx_01
   match identity group VPN_VOIP
   client authentication list vpn1
   isakmp authorization list vpn1
   client configuration address initiate
   client configuration address respond
crypto ipsec transform-set strong-encryption esp-3des esp-sha-hmac
crypto dynamic-map VPN_VOIP 2
set security-association idle-time 86400
set transform-set strong-encryption
set isakmp-profile VPN_VOIP
reverse-route
crypto map Ipsec-Static-msspain 60 ipsec-isakmp dynamic VPN_VOIP
interface GigabitEthernet0/0.533
encapsulation dot1Q xxx
ip address X.X.X.X 255.255.255.0
no ip proxy-arp
ip accounting output-packets
ip virtual-reassembly max-reassemblies 1024
ip local pool VPN_VOIP X.X.X.X X.X.X.X group VPN_VOIP
ip access-list extended VPN_VOIP
permit ip 10.10.0.0 0.0.255.255 any
Yes, I am sure because the IP is in range 10.10.10.0/24 and the ACL (VPN_VOIP) is /16. I ping to an IP of the range and sometimes don't.
Best regard,
Hello.
Your configuration looks fine, but I see no other interfaces in the VRF mentioned.
(You might have stripped "aaa author network vpn1 local").
1. Could you please trace 10.10.10.2 (.3) from the client?
2. Could you please try to ping the address from the Easy VPN server during the issue?
PS: the issue could be in the ommitted part of your configuration.
PS2: could you provide statistics screenshot per two cases (when you can/can't ping the IP-address)?
