Problem using access-lists in dynamic crypto maps to filter traffic
babanonyme
Hi all, I try to validate the use of set ip access-group in my crypto map, but I might be missing something here, as it's not working.
consider a simple network:
R2[F1/0]<===>10.0.0.0/24<===>[F1/1]R1[F1/0]<===>192.168.50.0/24<===>VPNCLIENT
Router running :
7200 Software (C7200-ADVIPSERVICESK9-M), Version 15.0(1)M, RELEASE SOFTWARE (fc2)
Common config:
hostname R1
aaa new-model
aaa authentication login VPN local
aaa authorization network VPN local
username cisco password 0 cisco
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group cisco
key cisco
pool VPNPOOL
acl VPNST
netmask 255.255.255.0
crypto ipsec transform-set TS1 esp-aes esp-sha-hmac
crypto ipsec profile pf1
set transform-set TS1
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface Loopback2
ip address 1.1.1.2 255.255.255.255
interface FastEthernet1/0
ip address 192.168.50.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/1
ip address 10.0.0.1 255.255.255.0
duplex auto
speed auto
router ospf 1
log-adjacency-changes
redistribute static metric 100 subnets
network 10.0.0.0 0.0.0.255 area 0
ip local pool VPNPOOL 192.168.12.1 192.168.12.10
ip access-list extended VPNFILTER
permit ip any host 1.1.1.1
deny   ip any any log
ip access-list extended VPNST
permit ip 1.1.1.0 0.0.0.255 any
permit ip 10.0.0.0 0.0.0.255 any
If I use crypto maps like this:
crypto dynamic-map DM 10
set ip access-group VPNFILTER in
reverse-route
crypto map CMAP client authentication list VPN
crypto map CMAP isakmp authorization list VPN
crypto map CMAP client configuration address respond
crypto map CMAP 10 ipsec-isakmp dynamic DM
crypto map CMAP
I can connect, and I can successfully ping all loopbacks addresses, and all devices behind my VPN router (in this case I ping R2, 10.0.0.2)
It's like the ACL is not applied. I even used a deny ip any any ACL and same result.
I managed to get this working using DVTI interfaces, but I'd like to know why it's not working with crypto maps.
FYI, configs w/ DVTI
no crypto map CMAP
crypto isakmp profile cisco
   match identity group cisco
   virtual-template 1
interface Virtual-Template1 type tunnel
ip unnumbered FastEthernet1/0
tunnel source FastEthernet1/0
tunnel mode ipsec ipv4
tunnel protection ipsec profile pf1
Any help would be much appreciated
0 Replies 0
