Problem VPN Gateway to Gateway RV042-Cisco 861
pperez1900
Hi. I'm having problems with an IPSec tunnel between an RV042 and a Cisco 861. I've configured the IKE, Transform Set, Access List and Crypto Map in the 861 trough the console and I've configured the tunnel in the RV042 web application with the same IKE, DH Group, encryption and Authentication but the connection doesn't work. Any advice or consideration for this type of connection?. Thank You.
jawad-mukhtar
Level 4
Level 4
Your Default Traffice will be natting towards outer World.
You have to No Nat Traffc From Source ip  to Destination ip that you allowed in VPN access list.
Simply mean deny source ip to destination ip in NAT ACL.
Jawad
jawad-mukhtar
Level 4
Level 4
Jawad
Thanks Jawad. I did that in the 861 I have to do it in the RV042. I'll work on it and let you know.
The tunnel is working now. The deny traffic part was missing and I had a problem with the ACL. Also the second phase SA time wasn't configurated. If someone is interested I can put some puntual configurations. Thanks for the help.
