problem when applying IPSEC to DMVPN
Hi i have some trouble with DMVPN
i configured NHRP between  a HUB and  aSPOKE:
               HUB
             tu0  tu1
                ISP
              tu0,tu1
             SPOKE
the HUB has two physical interfaces and two logical interfaces.
The SPOKE has one physical interface and two logical interfaces.
in configured NHRP correctly, the tunnels  are  detected in the HUB and the SPOKE.
when i add the profile IPSEC to the intefaces i lose tunnel1.
SPOKE1#sh ip nhrp
10.1.1.4/32 via 10.1.1.4, Tunnel0 created 02:22:01, never expire
  Type: static, Flags: authoritative used
  NBMA address: 190.1.1.1
10.2.2.4/32 via 10.2.2.4, Tunnel1 created 02:18:21, never expire
  NBMA address: 190.1.2.1
SPOKE1#debug ip nhrp
tunnel0
*Mar  1 03:50:09.399: NHRP: Attempting to send packet via DEST 10.1.1.4
*Mar  1 03:50:09.399: NHRP: Encapsulation succeeded.  Tunnel IP addr 190.1.1.1
*Mar  1 03:50:09.399: NHRP: Send Registration Request via Tunnel0 vrf 0, packet size: 82
*Mar  1 03:50:09.403:       src: 10.1.1.1, dst: 10.1.1.4
*Mar  1 03:50:09.403: NHRP: 82 bytes out Tunnel0
*Mar  1 03:50:09.519: NHRP: Receive Registration Reply via Tunnel0 vrf 0, packet size: 102
*Mar  1 03:50:09.519: NHRP: netid_in = 0, to_us = 1
tunnel 1
*Mar  1 03:50:30.575: NHRP: Attempting to send packet via DEST 10.2.2.4
*Mar  1 03:50:30.575: NHRP: Encapsulation succeeded.  Tunnel IP addr 190.1.2.1
*Mar  1 03:50:30.575: NHRP: Send Registration Request via Tunnel1 vrf 0, packet size: 82
*Mar  1 03:50:30.579:       src: 10.2.2.1, dst: 10.2.2.4
*Mar  1 03:50:30.579: NHRP: 82 bytes out Tunnel1
*Mar  1 03:50:30.579: NHRP: Resetting retransmit due to hold-timer for 10.2.2.4
no reply from the HUB.
HUB#sh ip nhrp
10.1.1.1/32 via 10.1.1.1, Tunnel0 created 00:05:05, expire 00:08:29
  Type: dynamic, Flags: authoritative unique registered
  NBMA address: 191.1.1.11
just tunnel0 is there !
i have also this on the HUB :
*Mar  1 03:58:54.519: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 191.1.1.11 (physical adress of  SPOKE1)
configs :
HUB :
crypto isakmp policy 10
encr aes
hash md5
authentication pre-share
group 2
crypto isakmp key techservices address 0.0.0.0 0.0.0.0
crypto ipsec transform-set AES_MD5 esp-aes esp-md5-hmac
crypto ipsec profile DMVPN
set transform-set AES_MD5
interface Tunnel0
bandwidth 10000
ip address 10.1.1.4 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 123
ip nhrp authentication dmvpn1
ip nhrp map multicast dynamic
ip nhrp network-id 123
no ip split-horizon eigrp 123
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 123
tunnel protection ipsec profile DMVPN
interface Tunnel1
bandwidth 10000
ip address 10.2.2.4 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 124
ip nhrp authentication dmvpn2
ip nhrp network-id 124
no ip split-horizon eigrp 124
tunnel source FastEthernet1/0
tunnel key 124
router eigrp 123
network 10.1.1.0 0.0.0.255
network 172.16.4.0 0.0.0.255
no auto-summary
router eigrp 124
network 10.2.2.0 0.0.0.255
no auto-summary
SPOKE1:
encr aes
hash md5
group 2
interface Tunnel0
bandwidth 10000
ip address 10.1.1.1 255.255.255.0
ip mtu 1400
ip nhrp map multicast 190.1.1.1
ip nhrp map 10.1.1.4 190.1.1.1
ip nhrp holdtime 600
ip nhrp nhs 10.1.1.4
ip nhrp registration timeout 300
tunnel key 123
interface Tunnel1
bandwidth 10000
ip address 10.2.2.1 255.255.255.0
ip mtu 1400
ip nhrp map multicast 190.1.2.1
ip nhrp map 10.2.2.4 190.1.2.1
ip nhrp nhs 10.2.2.4
tunnel key 124
router eigrp 123
network 172.16.1.0 0.0.0.255
no auto-summary
router eigrp 124
no auto-summary
regards
Good to hear. Looks like it could've been a timing issue. On recent releases a logic to restart the registration timer during some timing conditions caused by configuration sequence was added. Since you are using an old code that could be the reason why it worked after reconfiguring the tunnel interface.
P.D Make sure you mark this thread as answered so it can help others.
12 Replies 12
Gustavo Medina
Hello Abdelilah,
The problem here is on the Spoke; when multiple GRE over IPSec tunnels are sourced from the same interface, and at least one is an mGRE tunnel it becomes impossible to guarantee proper Tunnel interface selection.  This means that an incoming IPSec encrypted packet may be sent to the wrong Tunnel interface and then be unable to be decrypted as that Tunnel does not have the encryption/decryption information for that tunnel.  We will find that one of the tunnels may work and all others may fail.
Encryption/Decryption information is stored in a data structure that we call the SADB (Security Association Database).  The SADB is associated on a per interface basis and stores the encryption/decryption rules and keying data.  If a packet comes in to the wrong interface, and therefore the wrong SADB, the packet will be dropped because we cannot find the SPI (Security Parameter Index) in that SADB.
When it is not possible to select the proper interface, we share the same SADB across the tunnel interfaces associated with the same tunnel source.  Now we can be guaranteed that a packet can be decrypted and after decryption we have some more information to select the appropriate tunnel interface to drop the decrypted traffic in.
So that's why in your case we need to use Shared Tunnel Protection
interface Tunnel0
bandwidth 10000
ip mtu 1400
tunnel key 123
tunnel protection ipsec profile DMVPN shared
interface Tunnel1
bandwidth 10000
ip mtu 1400
tunnel key 124
Important notes:
a) The shared keyword must be applied to the tunnel protection command
b) The tunnel protection on each of the tunnels that use the shared interface must Use the same ipsec profile.  This profile should be different than other GRE/IPSec interfaces that are not sharing the SADB.
c) Each of the tunnels must have a unique tunnel key used to identify the traffic after it is decrypted.  The tunnel key must match the key defined on the other side of the tunnel.
thank you very much
Hello Gustavo
thank you it works
but when i add an other SPOKE there is a problem :
                          HUB
SPOKE1___ ISP__SPOKE2
HUB:
encr aes
hash md5
group 2
crypto isakmp key cisco address 0.0.0.0 0.0.0.0
interface Tunnel0
bandwidth 1000
no ip redirects
ip mtu 1400
tunnel key 123
interface Tunnel1
bandwidth 1000
no ip redirects
ip mtu 1400
tunnel key 124
router eigrp 123
no auto-summary
router eigrp 124
no auto-summary
SPOKE1 :
encr aes
hash md5
group 2
interface Tunnel0
bandwidth 1000
no ip redirects
ip mtu 1400
tunnel key 123
interface Tunnel1
bandwidth 1000
no ip redirects
ip mtu 1400
tunnel key 124
router eigrp 123
no auto-summary
router eigrp 124
no auto-summary
SPOKE2 :
encr aes
hash md5
group 2
interface Tunnel0
bandwidth 1000
ip address 10.1.1.2 255.255.255.0
no ip redirects
ip mtu 1400
tunnel key 123
interface Tunnel1
bandwidth 1000
ip address 10.2.2.2 255.255.255.0
no ip redirects
ip mtu 1400
tunnel key 124
router eigrp 123
network 172.16.2.0 0.0.0.255
no auto-summary
router eigrp 124
no auto-summary
HUB:
HUB#sh ip nhrp
10.1.1.1/32 via 10.1.1.1, Tunnel0 created 00:15:17, expire 00:09:21
10.1.1.2/32 via 10.1.1.2, Tunnel0 created 00:12:09, expire 00:07:50
  NBMA address: 191.1.1.12
10.2.2.1/32, Tunnel1 created 00:02:57, expire 00:00:07
  Type: incomplete, Flags: negative
  Cache hits: 7
10.2.2.2/32 via 10.2.2.2, Tunnel1 created 00:12:00, expire 00:07:58
HUB can't have the NBMA adress for 10.2.2.1 for SPOKE1
HUB#ping 10.2.2.1
Sending 5, 100-byte ICMP Echos to 10.2.2.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
*Mar  1 00:45:18.431: NHRP: MACADDR: if_in null netid-in 0 if_out Tunnel1 netid-out 124
*Mar  1 00:45:18.435: NHRP: Checking for delayed event 0.0.0.0/10.2.2.1 on list (Tunnel1).
*Mar  1 00:45:18.435: NHRP: No node found..
*Mar  1 00:45:07.131: NHRP: MACADDR: if_in null netid-in 0 if_out Tunnel1 netid-out 124
*Mar  1 00:45:07.131: NHRP: Checking for delayed event 0.0.0.0/10.2.2.1 on list (Tunnel1).
*Mar  1 00:48:30.759: NHRP: Checking for delayed event 0.0.0.0/10.2.2.1 on list (Tunnel1).
*Mar  1 00:48:30.763: NHRP: No node found.
*Mar  1 00:48:30.763: NHRP: Attempting to send packet via DEST 10.2.2.1
*Mar  1 00:48:30.767: NHRP: Send Resolution Request via Tunnel1 vrf 0, packet size: 82
*Mar  1 00:48:30.771:       src: 10.2.2.4, dst: 10.2.2.1
*Mar  1 00:48:30.771: NHRP: Encapsulation failed for destination 10.2.2.1 out Tunnel1
SPOKE1#
*Mar  1 00:53:38.695: NHRP: Setting retrans delay to 64 for nhs  dst 10.2.2.4
*Mar  1 00:53:38.699: NHRP: Attempting to send packet via DEST 10.2.2.4
*Mar  1 00:53:38.699: NHRP: Encapsulation succeeded.  Tunnel IP addr 190.1.2.1
*Mar  1 00:53:38.703: NHRP: Send Registration Request via Tunnel1 vrf 0, packet size: 82
*Mar  1 00:53:38.711:       src: 10.2.2.1, dst: 10.2.2.4
*Mar  1 00:53:38.715: NHRP: 82 bytes out Tunnel1
SPOKE1#ping 10.2.2.4
Sending 5, 100-byte ICMP Echos to 10.2.2.4, timeout is 2 seconds:
the SPOKE can't reach 10.2.2.4
after a few time :
HUB#sh ip nhrp
10.1.1.1/32 via 10.1.1.1, Tunnel0 created 00:25:03, expire 00:09:35
  Type: dynamic, Flags: authoritative unique registered used
10.1.1.2/32 via 10.1.1.2, Tunnel0 created 00:21:55, expire 00:08:03
10.2.2.2/32 via 10.2.2.2, Tunnel1 created 00:21:47, expire 00:08:12
only 3 tunnels
i need help please.
What version are you running on the failing spoke?
Can you try removing the entire tunnel config and pasting it again after a couple of minutes?
Hello
I configured everything again but the problem persists
if i use just one tunnel interface on spoke and change  the adresse 10.2.2.4 to 10.1.1.5 this will be a good choice?
i will put the two mapping for the two HUB  interfaces in that tunnel interface is that correct?
What is the version you are using? could you provide the debugs outputs from HUB and Failing Spoke so I can take a look?
HUB#sh version
Cisco IOS Software, 3600 Software (C3640-IK9O3S-M), Version 12.4(3), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 22-Jul-05 07:14 by hqluong
ROM: ROMMON Emulation Microcode
ROM: 3600 Software (C3640-IK9O3S-M), Version 12.4(3), RELEASE SOFTWARE (fc2)
HUB uptime is 0 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19
System image file is "tftp://255.255.255.255/unknown"
agree to comply with applicable laws and
*Mar  1 00:00:29.943: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to up
*Mar  1 00:00:30.563: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to upregulations. If you are unable
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3640 (R4700) processor (revision 0xFF) with 124928K/6144K bytes of memory.
Processor board ID FF1045C5
R4700 CPU at 100MHz, Implementation 33, Rev 1.2
4 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
125K bytes of NVRAM.
8192K bytes of processor board System flash (Read/Write)
SPOKE1#sh version
SPOKE1 uptime is 1 minute
export@cisco.com.
1 FastEthernet interface
wow that's old. I will need the complete configurations and debug outputs to find out what is the problem.
i configured it  one last time and it worked i really don't know why!
thank you Gustavo, very much for your help ,your comments were very informative
