Problem with (27 Ipsec & Oracle
xangles
I have a vpn between two Cisco 827 routers with IpSec, and i unable to connect to a oracle server, trought this vpn, the other protocols seems ok (I can use Telnet, ssh, ftp, smtp, ...)
Is there any incompatibility between oracle sqlnet and ipsec?
Xavi
j-block
Level 4
Level 4
It may not be a VPN problem. It’s probably NAT. Make sure the SQL packet doesn’t get NAT’d before it goes through the VPN tunnel and that that address is routable on the remote network.
