Problem with a s2s IP SEC between ASA and Adtran
HubTechAdmin
I'm having a problem getting this tunnel to come up.  What info would you guys need to help me out? I'm just cutting my teeth on networking i've always had guys to defer these problems to but I dont right now....
This is what keeps popping up in the logs
6Dec 08 201212:19:13713172
Group = x.x.x.x, IP = x.x.x.x, Automatic NAT Detection Status:     Remote end is NOT behind a NAT device     This   end is NOT behind a NAT device
  and
6Dec 08 201212:19:13302015OutsideIP500x.x.x.x500Built outbound UDP connection 1088 for outside:x.x.x.x/500 (x.x.x.x/500) to identity:OutsideIP/500 (OutsideIP/500)
and
4Dec 08 201212:19:33713903
Group = x.x.x.x, IP = x.x.x.x Information Exchange processing failed
there's a couple more logs, let me know if ya'll need anything else to help.
Jennifer Halim
a copy of the configuration of the ASA would help and also advise which vpn tunnel is to the adtran device.
also, if you can run the following debug:
debug cry isa
debug cry ipsec
and share the output when you try to ping between the 2 LANs.
