Problem with attribute radius IETF
rpaolet
Community Member
Q. How can I assign Domain Naming System (DNS) and Windows Internet Naming Service (WINS) server IP addresses for PPP connections from ACS using RADIUS?
A. You can specify DNS and WINS server IP addresses from the ACS on a per-user basis or for a group of users by adding the following lines under Cisco RADIUS Attributes and AV-pair in group setup.
ip:wins-server=123.1.1.1 123.1.1.2
ip:dns-servers=212.1.1.1 212.1.1.2
but i don't know how make ????
I'm using ACS ver 3.1 on Windows.
Can anyone help me ???
Roberto
mchin345
Level 11
Level 11
The above is true only is you are using CISCO access server, If you are using non-Cisco access server you need to use vendor specific attributes,
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/csnt30/user/ae.htm#72581
I have the same problem with tha acs 4.0. i have a vpn between the juniper that is the nas and an cisco router when the vpn ipsec ends. how can I configure the acs for the wins
thanks
Ira
