problem with cisco client 4.0.3(A) - xauth
p.dubicki
hi
I'm trying to connect w2k (cisco vpn client 4.0.3) with cisco vpn concentrator
but xauth doesnt work !!! my logs are:
Cisco Systems VPN Client Version 4.0.3 (A)
Copyright (C) 1998-2003 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.0.2195
225 10:46:34.578 04/19/04 Sev=Info/4 CM/0x63100002
Begin connection process
226 10:46:34.578 04/19/04 Sev=Info/4 CM/0x63100004
Establish secure connection using Ethernet
227 10:46:34.578 04/19/04 Sev=Info/4 CM/0x63100024
Attempt connection with server "xx.xx.xx.xx"
228 10:46:34.578 04/19/04 Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with xx.xx.xx.xx.
229 10:46:34.593 04/19/04 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Unity)) to xx.xx.xx.xx
230 10:46:34.703 04/19/04 Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
231 10:46:34.703 04/19/04 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
232 10:46:34.921 04/19/04 Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = xx.xx.xx.xx
233 10:46:34.921 04/19/04 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, KE, NON, ID, HASH, VID(Unity), VID(Xauth), VID(dpd), VID(Frag), VID(?), VID(?)) from xx.xx.xx.xx
234 10:46:34.921 04/19/04 Sev=Info/5 IKE/0x63000001
Peer is a Cisco-Unity compliant peer
235 10:46:34.921 04/19/04 Sev=Info/5 IKE/0x63000001
Peer supports XAUTH
236 10:46:34.921 04/19/04 Sev=Info/5 IKE/0x63000001
Peer supports DPD
237 10:46:34.921 04/19/04 Sev=Info/5 IKE/0x63000001
Peer supports DWR Code and DWR Text
238 10:46:34.937 04/19/04 Sev=Info/6 IKE/0x63000001
IOS Vendor ID Contruction successful
239 10:46:34.937 04/19/04 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, VID(?), VID(Unity)) to xx.xx.xx.xx
240 10:46:34.937 04/19/04 Sev=Info/4 IKE/0x63000082
IKE Port in use - Local Port = 0x01F4, Remote Port = 0x01F4
241 10:46:34.937 04/19/04 Sev=Info/4 CM/0x6310000E
Established Phase 1 SA. 1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
242 10:46:34.953 04/19/04 Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = 213.218.113.139
243 10:46:34.953 04/19/04 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from xx.xx.xx.xx
244 10:46:34.953 04/19/04 Sev=Info/4 CM/0x63100015
Launch xAuth application
245 10:46:35.000 04/19/04 Sev=Warning/3 CM/0xA3100012
Unable to forward xAuth request data to xAuth application. Error code 4294967283
246 10:46:35.000 04/19/04 Sev=Warning/2 IKE/0xE3000099
Failed to process Xauth Request (NavigatorTM:412)
247 10:46:35.000 04/19/04 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=6CC5B5C8B1A7D0EA R_Cookie=758B3064945FDC63) reason = DEL_REASON_CANNOT_AUTH
248 10:46:35.000 04/19/04 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, DWR) to xx.xx.xx.xx
249 10:46:35.687 04/19/04 Sev=Info/4 IKE/0x6300004A
Discarding IKE SA negotiation (I_Cookie=6CC5B5C8B1A7D0EA R_Cookie=758B3064945FDC63) reason = DEL_REASON_CANNOT_AUTH
250 10:46:35.687 04/19/04 Sev=Info/4 CM/0x63100014
Unable to establish Phase 1 SA with server "xx.xx.xx.xx" because of "DEL_REASON_CANNOT_AUTH"
251 10:46:35.687 04/19/04 Sev=Info/5 CM/0x63100025
Initializing CVPNDrv
252 10:46:35.687 04/19/04 Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
253 10:46:36.187 04/19/04 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
254 10:46:36.187 04/19/04 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
255 10:46:36.187 04/19/04 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
256 10:46:36.187 04/19/04 Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
p.dubicki
additional info:
when I'm trying to connect by command line interface od cvpn client by command:
vpnclient connect cliauth 'connection-name'
all works vell ...
that means GUI xauth doesn't work...
any idea why ?
