Problem with connection trough remote VPN connection to inside interface
eduardo.leyva
Hi i have a ASA 5510 with version 7.0 , i just configured a Remote IP Sec VPN, the vpn works fine when i try to connect to the hosts behind the inside interface, but when i try to connect to the inside interface of the asa for configuring it, i cannot establish te connection and i cannot ping the interface, i issued the permit same security interface intra interface, and the ssh 0.0 inside and telnet 0 0 inside commands on the asa but the connection cannot be established from the remote client vpn to the inside interface of the asa.
¿ Any ideas for fixing this little issue ?
Best Regards ELO !!
Divya Nair
Hey Eduardo,
Can you check if you have management-access inside enabled on the ASA?
Divya
