Problem with Destination NAT
Ratatapaa
Hello everybody, and sorry for making you help me again
I have an ASA 5505 here (code to be furnish at the end)
Please note that the IP adress for the outside interface are exemple since this is a lab atm
This router is gonna go inside   a small company.
This company use a SBS 2003 Server with exchange on it
So we need the route to do 3 things
1) Make the local lan access the internet : This is working as inteded
2) Make a VPN from the outside and access the lan : This is also working
3) We want to make people (after we change the DNS for it) to be able to do exemple mail.aaa.aaa and be able to access the Mail server from Outlook without beein on the internet and the OWA from the browser
Currently we only have 1 IP adress from the ISP, so i need to be able to access it from the same IP as the VPN (if possible)
I wanna know how to make it work as exemple just beein able to access port 25 from it
And how to make it accessible from multiple ports exemple 110 25 587 etc (all email ports)
my inside mail server is 192.168.0.2
How can i make this work
If you have any question don<t hesitate to ask i<ll do my best to answer
ASA Version 8.2(1)
terminal width 250
hostname hostname
enable password d0/xPtlKePBzdYTe encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 10.0.128.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
speed 10
duplex full
interface Ethernet0/1
speed 10
duplex full
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa821-k8.bin
ftp mode passive
object-group service grp_outside_in tcp
description Ports require for internal forwarding
port-object eq smtp
port-object eq ssh
access-list inside-out extended permit ip any any
access-list inside-out extended permit icmp any any
access-list no_nat extended permit ip 192.168.0.0 255.255.0.0 10.250.128.0 255.255.255.0
access-list split-tunnel extended permit ip 192.168.0.0 255.255.20.0 10.250.128.0 255.255.255.0
access-list 100 extended permit ip 10.250.128.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list 100 extended permit icmp 10.250.128.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list 101 extended permit ip any any
access-list 101 extended permit icmp any any
pager lines 34
logging enable
logging timestamp
logging buffered debugging
logging trap debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool mobilepool 10.250.128.100-10.250.128.130 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-621.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list no_nat
nat (inside) 1 0.0.0.0 0.0.0.0
nat (outside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 10.0.128.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set mobileset esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map dyn1 1 set transform-set mobileset
crypto dynamic-map dyn1 1 set reverse-route
crypto map mobilemap 1 ipsec-isakmp dynamic dyn1
crypto map mobilemap interface outside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 192.168.0.0 255.255.255.0 inside
ssh 10.0.128.0 255.255.255.0 inside
ssh timeout 5
ssh version 2
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy vpn internal
group-policy vpn attributes
vpn-simultaneous-logins 50
vpn-idle-timeout 2000
vpn-session-timeout 2000
group-policy mobile_policy internal
group-policy mobile_policy attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value
username admin password N2TJh8TeuGc7EOVu encrypted privilege 15
username user1 password gLGaPhl70GqS8DhN encrypted
username user2 password Y7.fXmPk3FvKUGOO encrypted
tunnel-group mobilegroup type remote-access
tunnel-group mobilegroup general-attributes
address-pool mobilepool
default-group-policy mobile_policy
tunnel-group mobilegroup ipsec-attributes
pre-shared-key *
class-map global-class
match default-inspection-traffic
class-map inspection
class-map inspection_default
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:012d58f20bdf997d1e7b6927431e0015
: end
Here you go:
static (inside,outside) tcp 10.0.128.3 25 192.168.0.2 25 netmask 255.255.255.255
static (inside,outside) tcp 10.0.128.3 110 192.168.0.2 110 netmask 255.255.255.255
static (inside,outside) tcp 10.0.128.3 587 192.168.0.2 587 netmask 255.255.255.255
static (inside,outside) tcp 10.0.128.3 443 192.168.0.2 443 netmask 255.255.255.255
access-list outside-acl permit tcp any host 10.0.128.3 eq 25
access-list outside-acl permit tcp any host 10.0.128.3 eq 110
access-list outside-acl permit tcp any host 10.0.128.3 eq 587
access-list outside-acl permit tcp any host 10.0.128.3 eq 443
access-group outside-acl in interface outside
Ratatapaa
I made a mini mistake
we got 2 IP adress from our ISP, but I wanna kinda assign both to ETH0/0
So  exemple 10.0.128.1 for VPN (works)
10.0.128.3 NAT to 192.168.0.2 for Email server (but only specified ports)
Here you go:
Thanks alot it worked, sorry for the late answer had lot of work
I have a 2nd problem if you can help me for the same setup kinda
The lan of the office is 192.168.0.0/24 (a bit dumb but sadly too many stuff to do to change it)
So i would like to be able to say exemple
On the VPN connection (IP adress from the pool 10.250.128.0) if i wanna RDP on exemple PC 192.168.0.200 instead in my RDP program i type 192.168.200.200 and the cisco will convert it to 192.168.0.200
I hope you can help me, (same config as the first post)
Sorry about all these questions but these config are a bit advance for my knowledge but still learning!
