Problem with Dynamic P2P VTI Tunnel
Hi there,
Looking for the help with resolving the isakmp phase1 issue.
There are two 2691 routers: R3 is hub, R1 is spoke.
I have Virtual-Template interface on R3 and Tunnel0 interface on R1.
I have the same key in "crypto isakmp key" on R1 and in "keyring address" on R3.
Here is the piece of debug from R3:
*Mar  1 03:07:05.167: ISAKMP:(1093): processing ID payload. message ID = 0
*Mar  1 03:07:05.167: ISAKMP (0:1093): ID payload
        next-payload : 8
        type         : 1
        address      : 192.168.1.1
        protocol     : 17
        port         : 500
        length       : 12
*Mar  1 03:07:05.171: ISAKMP:(0):: peer matches VPN profile
*Mar  1 03:07:05.171: ISAKMP:(1093):Found ADDRESS key in keyring VPN
*Mar  1 03:07:05.171: ISAKMP:(1093):Key not found in keyrings of profile , aborting exchange
*Mar  1 03:07:05.171: ISAKMP (0:1093): FSM action returned error: 2
*Mar  1 03:07:05.171: ISAKMP:(1093):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
*Mar  1 03:07:05.171: ISAKMP:(1093):Old State = IKE_R_MM5  New State = IKE_R_MM5
*Mar  1 03:07:05.175: ISAKMP:(1093):peer does not do paranoid keepalives.
*Mar  1 03:07:05.175: ISAKMP:(1093):deleting SA reason "IKMP_ERR_NO_RETRANS" state (R) MM_KEY_EXCH (peer 192.168.1.1)
*Mar  1 03:07:05.175: ISAKMP (0:1093): FSM action returned error: 2
*Mar  1 03:07:05.175: ISAKMP:(1093):Input = IKE_MESG_INTERNAL, IKE_PROCESS_ERROR
*Mar  1 03:07:05.175: ISAKMP:(1093):Old State = IKE_R_MM5  New State = IKE_R_MM4
Here is "sh crypto isakmp sa" payload from R3:
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id slot status
10.10.10.2      192.168.1.1     MM_NO_STATE       1096    0 ACTIVE (deleted)
And here is isakmp sa state from R1:
10.10.10.2      192.168.1.1     MM_KEY_EXCH       1093    0 ACTIVE
ISAKMP phase 1 stucks on this.
I will show router's running-config pieces in the next message.
Looking forward for your help.
R1 running-config:
crypto isakmp policy 10
encr aes
authentication pre-share
group 5
crypto isakmp key 12345 address 10.10.10.2
crypto ipsec transform-set VPN esp-aes esp-sha-hmac
crypto ipsec profile VPN
set transform-set VPN
interface Tunnel0
ip unnumbered FastEthernet0/0
tunnel source FastEthernet0/0
tunnel destination 10.10.10.2
tunnel mode ipsec ipv4
tunnel protection ipsec profile VPN
interface FastEthernet0/0
ip address 192.168.1.1 255.255.255.252
R3 running-config:
crypto keyring VPN
  pre-shared-key address 192.168.1.1 key 12345
encr aes
group 5
crypto isakmp key 12345 address 192.168.1.1
crypto isakmp profile VPN
   keyring VPN
   match identity address 192.168.1.1 255.255.255.255
   match identity address 172.16.0.1 255.255.255.255
   virtual-template 1
interface FastEthernet1/0
ip address 10.10.10.2 255.255.255.252
duplex auto
speed auto
interface Virtual-Template1 type tunnel
ip unnumbered FastEthernet1/0
