Problem with GRE over IPSEC Implementation
Blue_Bird
Hello I am trying implement gre with ipsec....before ipsec implemenation....I am able to ping from R1 loopback to R3 loopback. But, after ipsec implemenation no communication between them...any help appreciated..!!
Here is the configuration for R1 and R3
R1
ip tcp synwait-time 5
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key cisco@123 address 3.3.3.3
crypto ipsec transform-set TS1 esp-3des esp-md5-hmac
mode transport
crypto ipsec profile protect-gre
set security-association lifetime seconds 86400
set transform-set TS1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Tunnel0
ip address 172.16.0.1 255.255.255.0
tunnel source FastEthernet0/0
tunnel destination 192.168.23.3
tunnel protection ipsec profile protect-gre
interface FastEthernet0/0
ip address 192.168.12.1 255.255.255.0
speed auto
duplex auto
interface FastEthernet0/1
no ip address
shutdown
speed auto
duplex auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 3.3.3.3 255.255.255.255 FastEthernet0/0
ip route 192.168.23.0 255.255.255.0 FastEthernet0/0
access-list 101 permit ip host 1.1.1.1 host 3.3.3.3 log
R3
encr 3des
hash md5
group 2
crypto isakmp key cisco@123 address 1.1.1.1
crypto ipsec transform-set TS3 esp-3des esp-md5-hmac
mode transport
set transform-set TS3
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface Tunnel0
ip address 172.16.0.3 255.255.255.0
tunnel destination 192.168.12.1
ip address 192.168.23.3 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip http server
ip route 1.1.1.1 255.255.255.255 FastEthernet0/0
ip route 192.168.12.0 255.255.255.0 FastEthernet0/0
2 Accepted Solutions
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
crypto isakmp key cisco@123 address 200.0.0.3
crypto ipsec profile prof
interface Loopback0
interface Tunnel0
ip address 5.0.0.1 255.255.255.0
tunnel destination 200.0.0.3
tunnel protection ipsec profile prof
ip address 100.0.0.1 255.255.255.0
duplex full
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet3/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet3/1
no ip address
shutdown
speed auto
duplex auto
no ip http server
ip route 0.0.0.0 0.0.0.0 100.0.0.2
ip route 3.3.3.3 255.255.255.255 Tunnel0
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
crypto isakmp key cisco@123 address 100.0.0.1
interface Loopback0
interface Tunnel0
ip address 5.0.0.3 255.255.255.0
tunnel source FastEthernet1/1
tunnel destination 100.0.0.1
no ip address
shutdown
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 200.0.0.3 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip http server
ip route 0.0.0.0 0.0.0.0 200.0.0.2
ip route 1.1.1.1 255.255.255.255 Tunnel0
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Sorry for the late response..!!
it work's perfectly..!! Thanks for the configuration..!!
previously... i used crypto isakmp key cisco@123 address 3.3.3.3, changed to crypto isakmp key cisco@123 address 192.168.23.3
same way I changed  in R3 crypto isakmp key cisco@123 address 1.1.1.1 changed to crypto isakmp key cisco@123 address 192.168.12.1
12 Replies 12
Only one step wrong
Instead of using LO IP in crypto isakmp key use tunnel destination.
That it
Do change abd check
Note:- you need static route in each peer of LO the egress interface will be tunnel interface' this route based vpn not policy vpn' so traffic need to encrypt must pass through tunnel
MHM
Still tunnel status is Down
I have done following changes
R1
crypto isakmp key cisco@123 address 172.16.0.3
R3
ip route 1.1.1.1 255.255.255.255 tunnel 0
crypto isakmp key cisco@123 address 172.16.0.1
Tunnel destination not tunnel IP
Use 192.168.12.1 and 192.168.23.3
MHM
I changed  to physical int  ip's
R1--> crypto isakmp key cisco@123 address 192.168.23.3
R3--> crypto isakmp key cisco@123 address 192.168.12.1
Still...status down...
If you remove ipsec profile form tunnel
And do show ip interface breif
Do you see tunnel up/up?
MHM
Yes...it is up
Show ip route in both peer
MHM
this lab for you
check the routing
and use tunnel destination in crypto isakmp key
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
interface Tunnel0
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
interface Tunnel0
no ip address
shutdown
duplex full
no ip address
shutdown
speed auto
duplex auto
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Any update about this issue?
MHM
You are so welcome friend
MHM
