Problem with IPSEC
mzolee166
Community Member
Hello!
First sorry about my bad english.
I configured remote-access vpn on a 2610 router and work fine, i didn't change anything (i think), but once after I connected i can't reach the inside web server or hosts. I monitored the traffic with tcpdump and it show the remote vpn client ip address. Routing problem ?
My config:
aaa authentication login default local
aaa authentication login VPN_CLIENT_LOGIN local
aaa authentication ppp default local
aaa authorization network VPN_CLIENT_GROUP local
aaa session-id common
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group VPN_CLIENTS
key *****
dns 172.16.100.193
pool IPSEC
acl 110
crypto isakmp client configuration group VPN_CLIENTS_FULL  <- NO SPLIT TUNNEL
key *****
dns 172.16.100.193
pool IPSEC
crypto ipsec transform-set TRANS_3DES_SHA esp-3des esp-sha-hmac
crypto dynamic-map EXT_DYNAMIC_MAP 10
set transform-set TRANS_3DES_SHA
reverse-route
crypto map EXT_MAP client authentication list VPN_CLIENT_LOGIN
crypto map EXT_MAP isakmp authorization list VPN_CLIENT_GROUP
crypto map EXT_MAP client configuration address respond
crypto map EXT_MAP 10 ipsec-isakmp dynamic EXT_DYNAMIC_MAP
interface Loopback2
ip address 172.16.100.129 255.255.255.224
ip nat inside
interface Ethernet0/0
description OUTSIDE_PORT
ip address 172.19.10.2 255.255.0.0
ip nat outside
ip route-cache policy
ip policy route-map ROUTEMAP
full-duplex
ip local pool IPSEC 172.16.100.130 172.16.100.158
ip nat inside source list 101 interface Ethernet0/0 overload
access-list 101 deny   ip 172.16.100.32 0.0.0.31 172.16.100.128 0.0.0.31
access-list 101 deny   ip 172.16.100.192 0.0.0.31 172.16.100.128 0.0.0.31
access-list 101 deny   ip 172.16.100.128 0.0.0.31 172.16.100.128 0.0.0.31
access-list 101 permit ip any any
access-list 102 permit ip 172.16.100.128 0.0.0.31 any
access-list 102 deny   ip any any
access-list 110 permit ip 172.16.100.32 0.0.0.31 172.16.100.128 0.0.0.31
access-list 110 permit ip 172.16.100.192 0.0.0.31 172.16.100.128 0.0.0.31
access-list 110 permit ip 172.16.100.128 0.0.0.31 172.16.100.128 0.0.0.31
route-map ROUTEMAP permit 10
match ip address 102
set interface Loopback2
mzolee166
Community Member
I found something. Without split acl, tracert send every packet to my router. Dns lookup with my router working
Andrew Phirsov
Level 11
Level 11
What's your inside subnet, where the servers are located? Anyway the split acl in the config provided doesn't make sense, cause with it only traffic from vpn-pool to vpn-pool subnet is tunneled. Plus, because you're trying to direct all the traffic (at least http) through the tunnel, according to the route-map configuration, the split-acl is not required at all.
If by saying this you mean, that on some server you see packets from the client, check that the server have a route to the vpn-pool subnet through inside interface of the ISR.
mzolee166
Community Member
I found someting again. When i type the webserver's ip address in the browser, on a remote client, the request is came to the outside wan (172.19.10.2) ip address, not to the inside address 172.16.100.204. i installed another web server other pc and the client can reach it, after that i remove the static nat to 204 and worked. Any idea why ?
mzolee166
Community Member
I found the problem and the solution. The problem was between the static nat and the ipsec. I add static nat with route-map.
