Problem with Modem Connection
I´m trying to use a modem to connect a serial interface (router 1721) through cell access. The problem is that I can establish connection sometimes and sometimes not. The debug messages, when I can not establish connection, are:
2d16h: Se0 DDR: disconnecting call
2d16h: Di1: No free dialer - starting fast idle timer.
2d16h: Di1: No free dialer - starting fast idle timer..
2d16h: Se0 DDR: re-enable timeout
2d16h: Se0 DDR: rotor dialout [best] least recent failure is also most recent failure
2d16h: Se0 DDR: rotor dialout [best] also has most recent failure
2d16h: Se0 DDR: Dialing cause ip (s=10.179.103.200, d=192.168.225.100)
2d16h: Se0 DDR: Attempting to dial #777
2d16h: CHAT1: Attempting async line dialer script
2d16h: CHAT1: Dialing using Modem script: dial & System script: none
2d16h: CHAT1: process started
2d16h: CHAT1: Asserting DTR
2d16h: CHAT1: Chat script dial started
2d16h: CHAT1: Chat script dial finished, status = Success..
The configuration in dialer interface is:
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer remote-name pdsn
dialer idle-timeout 300
dialer string "#777" modem-script dial
dialer-group 1
no fair-queue
no cdp enable
ppp authentication chap callin
ppp chap hostname XXX
ppp chap password 0 XXX
I don´t know what else to do, please give me some advices.
Thanks.
icabrera
Level 8
Level 8
Hello, try to configure the command "dialer fast-idle X", the default of x is 20sec., you can configure 5 seconds for example.
First of all thank you for your help, but it didn´t work. It was able to connect through the modem once but after that it hadn´t been able again. It´s really weird this behaviour because sometimes it can connected and sometimes not.
What else can I do??
Hello, perhaps the modem doesn't disconnect properly, use the debug commands "debug modem" or similars, see the next url:
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a00801d2576.shtml
