Problem with remote access to ISDN Router
vasco.alcantara
I have the current setup:
PC->ISDN modem->PSTN->PBX->MGCP Voice gateway-> CCM -> H323 Voice Gateway w/vwic-2bri-nt/te->ISDN router
When i try to dialin to the ISDN Router from the PC I see the call made successfully but disconnects after 10 seconds and i'm not able to authenticate with the ISDN Router.
In attach is the debug q931 output. Has anybody seen this before?
Thanks in advance,
Vasco
paolo bevilacqua
I don't think you can get this to work with mgcp. You may have better chances using H.323 instead and if the hardware allows you, configure a dial-peer data as the newest IOS allows.
How do i use the data dial-peer?
Can i assign a port to it?
