problem with VPN connection from VPN client to HO PIX
jain.nitin
Level 3
Level 3
HI All, I am facing a problem with one of my branch users. Actaully branch users are not able to communicate with Head Office server over vpn using cisco VPN client. At head office vpn is terminating on cisco router & behind it there is PIX firewall. at branch office we have PIX firewall on which we have terminated our ADSL connection with static public ip assigned by ISP. Now the problem is that when i remove the PIX from branch office & connect the adsl directly to a PC users r successfully connecting to VPN & can communicate to HO server but when I install PIX at branch office then they successfuly connect to vpn, get the IP from HO cisco router but not able to communicate with HO servers infect any IP at HO. Please help me its very urgent. I am attaching the config of HO-Router,HO-PIX & branch office PIX.
vkapoor5
Level 5
Level 5
Before you can establish a VPN connection, you must have:
At least one connection entry configured on the VPN Client
User authentication information. This includes your username and password, and depending on the configuration of your connection entry, might also include:
Passwords for RADIUS authentication
VPN group name and password for connections to VPN devices
PINs for RSA Data Security
Digital certificates and associated passwords
An Internet connection
Jon Marshall
I think the problem you have here is that the Pix 506 is doing PAT and you have no exemption for your VPN clients. You can do one of two things
1) Enable NAT-T on your headend router.
2) Create a NAT exemption for the VPN clients on your Pix506.
Attached is a link to a Cisco doc for troublshooting common IPsec problems. Both solutions 1 & 2 are covered in this doc.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml
Jon
Thanks Jon,
Its working. We have enabled NTA-T at head end router now PIX 506 side client are able to access HO but now I have another problem, problem is other vpn client is now facing slowness which were working fine before connecting this new branch.Actually we upgrade the IOS of this headend router along with enabling NAT-T. I dont know where is the problem now.
please help me.
Ninja
