Problem with VPN. Router doesn't encrypt but does decrypt
pperez1900
Hello, I have a problem in my IPSec tunnel. One of the routers (Cisco 861) doesn't encrypt the packets but does decrypt the incoming ones from the remote peer (RV042). In the access-list for the wan interface I deny the traffic between the subnets and in the vpn access-list I permit the traffic. Could anyone give me some help or advice. Thanks.
The problem is with access-list 102.  That is your NAT access list.  You see that you are permitting 172.16.2.0  to any before you are denying, so all traffic is getting translated to your public IP address before attempting to go across the VPN.  You will always want to DENY traffic before you do any permits in an access-list because they process from top to bottom on first match.
Try the following commands:
no ip nat inside source list 102 interface FastEthernet4 overload
no access-list 102
access-list 102 deny   ip 172.26.2.0 0.0.0.255 172.26.3.0 0.0.0.255
access-list 102 permit ip 172.26.2.0 0.0.0.255 any
jj27
Can you post your configuration?
Here's my vpn configuration in th 861 side. I can't ping 172.26.3.1.
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key mykey address ip_remote
crypto ipsec transform-set cobts esp-3des esp-md5-hmac
crypto map CMAP1 1 ipsec-isakmp
set peer ip_remote
set security-association lifetime seconds 190
set transform-set cobts
match address vpn2
description ***
ip address wan_ip wan_mask
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map CMAP1
interface Vlan1
description ***
ip address 172.26.2.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 ip_gateway
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip access-list extended vpn2
permit ip 172.26.2.0 0.0.0.255 172.26.3.0 0.0.0.255
permit icmp 172.26.2.0 0.0.0.255 172.26.3.0 0.0.0.255
logging trap debugging
no cdp run
Thanks for the help.
no access-list 102
That was the problem. I didn't know the order matters. Thank you very mucho for your help.
