Problem with VPN traffic
asonea
I have configurated a site to site VPN and it is working ok. I can receive and send data. The VPN main configuration is the following:
- Remote Addres: X.X.0.0/15
- Local Range: Firewall Inside IP (172.16.0.1) and the range 172.16.2.2-172.16.2.255. We have been asked to NAT this IPs to the range 100.104.0.0/24. This NAT needs one to one address translation. For this I have created one NAT from 172.16.0.1 to 100.104.0.1 and other one from the range 172.16.2.2-255 to 100.104.0.2-255.
I have checked the VPN and everithing seems to be OK.
I need to send data from the firewall on the VPN. When I use packet tracer to check if everything is correct from 172.16.0.1 the traffic is denied by an Implicit Rule. But if I use one IP from the range 172.16.2.2-255 the traffic can leave the firewall and go through the VPN. I have an access rule created which allows all the trafic from inside to leave the firewall and another one created also to permit traffic from 172.16.0.1 to X.X.0.0/15.
I don't understand why I have this problem just with the firewall IP.
Could anyone help me please?
Thank you in advance.
21 Replies 21
Yes But this IP is not NAT as you mention in your original post
can I see how you config NAT and how you config ACL of VPN
MHM
Yes,
I have two NATs created:
19 (inside) to (outside) source static firewall fw_NAT destination static Remote_network Remote_network net-to-net no-proxy-arp
translate_hits = 0, untranslate_hits = 0
20 (inside) to (outside) source static red_interna red_nat destination static Remote_network Remote_network net-to-net no-proxy-arp
translate_hits = 152, untranslate_hits = 152
The first NAT translates the Ip from the firewall 172.16.0.1 to 100.104.0.1 and the second one the range 172.16.2.2-255 to 100.104.2-255.
The ACL of the VPN is:
access-list outside_cryptomap line 1 extended permit ip 100.104.0.0 255.255.255.0 Remote_network (hitcnt=195) 0x3119a0fa
this NAT never hit
the object network firewall AND fw_NAT must have contain host IP, am I correct ?
MHM
Yes this NAT never hit I do not understand why. The second one all the traffic is from pings I made.
Yes the object are the following:
host 172.16.0.1
object network fw_NAT
host 100.104.0.1
Hi Friend
I dot many test in my lab
Case1
10.0.0.0-ASA1-IPsec VPN-ASA2-20.0.0.0
VPC3 can ping ASA2 IN interface of ASA2 over IPsec when I run management-access IN
Case2
10.0.0.0-ASA1-IPsec-ASA2-220.0.0.0 NAT to 20.0.0.0
VPC3 can ping to VPC4 (static nat 220.0.0.4 to 20.0.0.4) but
VPC3 can not ping ASA2 IN interface (static nat 220.0.0.2 to 20.0.0.2)
I will try VTI and update you
MHM
asonea
Hello! Thank you again for your help.
I have checked again and now I see traffic on the NAT:
translate_hits = 80, untranslate_hits = 80
translate_hits = 8, untranslate_hits = 8
I can ping from my server and see the other side of the VPN (not from the firewall).
On the NAT 19 which is the one the SNMP should use I see traffic. On the syslog I see how from the other side they make ab UDP connection and it goes through the NAT.
6Jul 01 202412:56:37 X.X.X.X19001172.16.0.1161Built inbound UDP connection 1024028 for outside:X.X.X.X/19001 (X.X.X.X/19001) to inside:172.16.0.1/161 (100.104.0.1/161)
But again I check the SNMP and this traffic does not go through the VPN.
Any idea why this happens?
Thank you very much.
I get same in my lab, I can NAT but the traffic not pass between two Peer Over IPsec.
MHM
