Problems accessing IPsec tunnel to other LAN
kawin
Greetings,
I have successfully created a Lan-to-LAN VPN tunnel between a Cisco 2620 router to a VPN 3000 Concentrator to another location. In addition, I am able to dial-up to an ISP and connect to the 2620 router via VPN Client 3.5.
Is it possible for the client to access the remote LAN? I can access the local LAN with the Client, but not the other LAN we have a VPN connection with. The access-lists allow the assigned IP for the client to get into the remote network, and the remote end allows the IP subnet of the IP pool given to the remote client to get into their LAN as well.
Any help would be greatly appreciated!
Kawin
kawin
Disregard the above. The remote LAN was at fault.
