Problems connecting to Cisco 3000 from XP w/4.0.4 client
andrewmadrid
I am having an issue with one laptop not being able to connect to my VPN concentrator from Ethernet or wireless, but dial up works fine. I have disabled the XP firewall, disabled TCP/IP filtering, disabled the IPSec service and still nothing, This same exact client works on other XP machines (built from same image), but this one laptop will not connect. Here is the client log...
Cisco Systems VPN Client Version 4.0.4 (Rel)
Copyright (C) 1998-2003 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600
49 15:58:21.226 07/14/04 Sev=Info/4 CM/0x63100002
Begin connection process
50 15:58:21.246 07/14/04 Sev=Info/4 CM/0x63100004
Establish secure connection using Ethernet
51 15:58:21.246 07/14/04 Sev=Info/4 CM/0x63100024
Attempt connection with server "1.0.1.0"
52 15:58:21.246 07/14/04 Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with 1.0.1.0.
53 15:58:21.256 07/14/04 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Nat-T), VID(Frag), VID(Unity)) to 1.0.1.0
54 15:58:21.516 07/14/04 Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
55 15:58:21.516 07/14/04 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
56 15:58:26.503 07/14/04 Sev=Info/4 IKE/0x63000021
Retransmitting last packet!
57 15:58:26.503 07/14/04 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (Retransmission) to 1.0.1.0
58 15:58:31.510 07/14/04 Sev=Info/4 IKE/0x63000021
59 15:58:31.510 07/14/04 Sev=Info/4 IKE/0x63000013
60 15:58:36.518 07/14/04 Sev=Info/4 IKE/0x63000021
61 15:58:36.518 07/14/04 Sev=Info/4 IKE/0x63000013
62 15:58:41.525 07/14/04 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=xxxxxxxxxxxxxxxxxx_Cookie=yyyyyyyyyyyyyyyyyyyyy) reason = DEL_REASON_PEER_NOT_RESPONDING
63 15:58:42.036 07/14/04 Sev=Info/4 IKE/0x6300004A
Discarding IKE SA negotiation (I_Cookie=xxxxxxxxxxxxxxxx_Cookie=yyyyyyyyyyyyyyyyyyyyyyyy) reason = DEL_REASON_PEER_NOT_RESPONDING
64 15:58:42.036 07/14/04 Sev=Info/4 CM/0x63100014
Unable to establish Phase 1 SA with server "1.0.1.0" because of "DEL_REASON_PEER_NOT_RESPONDING"
65 15:58:42.036 07/14/04 Sev=Info/5 CM/0x63100025
Initializing CVPNDrv
66 15:58:42.046 07/14/04 Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
67 15:58:43.057 07/14/04 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
68 15:58:43.057 07/14/04 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
69 15:58:43.057 07/14/04 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
70 15:58:43.057 07/14/04 Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
Any ideas would be much appreciated!!!!
Thanks!
Andrew
nikhil_m
Any update on this ?
seekerzero
Dear Andrew,
I faced sort of the same issue as could not logon to VPN with the certificate on my XP laptop using DUN. I dont know the reason why but I fixed it by rebuilding the OS. Would you mind telling me which documents that shows how to connect VPN using Ethernet & wireless as it is my current project right now. thanks.
