Problems with Cisco AnyConnect Secure Mobility Client 3.1
real.solutions
Since I upgraded to Cisco AnyConnect Secure Mobility Client 3.1, I am unable to start my VPN.
The service does not start correctly anymore. I tried reinstabut no help.
Could anyone help me please?
Here my logs.
Thank you very much.
Date        : 07/23/2013
Time        : 08:49:37
Type        : Error
Source      : acvpninstall
Description : Function: FileMoveFiles
File: ..\Common\Utility\NativeSysFileCopy.cpp
Line: 388
Invoked Function: ::FindFirstFile
Return Code: 3 (0x00000003)
Description: The system cannot find the path specified.
Date        : 07/23/2013
Time        : 08:49:37
Type        : Error
Description : Function: wWinMain
File: .\InstallHelper.cpp
Line: 354
Invoked Function: FileMoveFiles
Return Code: -33554423 (0xFE000009)
Description: GLOBAL_ERROR_UNEXPECTED
Date        : 07/23/2013
Time        : 08:49:37
Type        : Error
Line: 388
Date        : 07/23/2013
Time        : 08:49:37
Type        : Error
Line: 354
Date        : 07/23/2013
Time        : 08:49:37
Type        : Error
Line: 388
Date        : 07/23/2013
Time        : 08:49:37
Type        : Error
Line: 354
Date        : 07/23/2013
Time        : 08:49:40
Type        : Information
Source      : acvpnva
Description : Function: CInstaller::PerformAction
File: .\VACon.cpp
Line: 522
Successfully installed service acsock
Date        : 07/23/2013
Time        : 08:49:40
Type        : Warning
Description : Function: XmlLocalACPolMgr::GenerateLocalPolicy
File: .\Xml\XmlLocalACPolMgr.cpp
Line: 415
Local Security Policy file already exists and therefore will not be generated
Date        : 07/23/2013
Time        : 08:49:40
Type        : Information
Source      : acvpnagent
Description : Cisco AnyConnect Secure Mobility Client Agent starting, version 3.1.04059
Date        : 07/23/2013
Time        : 08:49:40
Type        : Error
Source      : acvpnagent
Description : Function: CBencodeStream::LoadStream
File: ..\..\PhoneHome\Bencode.cpp
Line: 126
Unable to open file for reading
Date        : 07/23/2013
Time        : 08:49:40
Type        : Error
Source      : acvpnagent
Description : Function: CBencodeDictionary::CBencodeDictionary
Line: 1422
Bencode dictionary internalize failed
Date        : 07/23/2013
Time        : 08:49:40
Type        : Error
Source      : acvpnagent
Description : Function: CPhoneHomeVpn::CPhoneHomeVpn
File: .\PhoneHomeVpn.cpp
Line: 187
Failed to create Bencode dictionary
Date        : 07/23/2013
Time        : 08:49:40
Type        : Error
Source      : acvpnagent
Description : Function: CPhoneHomeVpn::CreateSingletonInstance
Line: 82
Invoked Function: CPhoneHomeVpn
Return Code: -23396343 (0xFE9B0009)
Description: PHONEHOMEVPN_ERROR_UNEXPECTED
Date        : 07/23/2013
Time        : 08:49:40
Type        : Warning
Source      : acvpnagent
Description : Function: CMainThread::CMainThread
File: .\MainThread.cpp
Line: 1017
Invoked Function: CPhoneHomeVpn::CreateSingletonInstance
Date        : 07/23/2013
Time        : 08:49:40
Type        : Warning
Source      : acvpnagent
Description : Function: PluginLoader::QuickCreatePlugin
File: c:\temp\build\thehoff\ElGreco_MR40.391570230547\ElGreco_MR4\vpn\Common\Utility/PluginLoader.h
Line: 195
Invoked Function: PluginLoader::CreateInstance
Return Code: -29360116 (0xFE40000C)
Description: PLUGINLOADER_ERROR_COULD_NOT_CREATE
com.cisco.anyconnect.leaf
Date        : 07/23/2013
Time        : 08:49:41
Type        : Information
Source      : acvpnagent
Description : Function: MsgCatalog::initMsgCatalog
File: .\i18n\MsgCatalog.cpp
Line: 246
Current locale: fr-LU
Date        : 07/23/2013
Time        : 08:49:41
Type        : Information
Source      : acvpnagent
Description : Function: ProfileMgr::loadProfiles
File: .\ProfileMgr.cpp
Line: 100
No profile is available.
Date        : 07/23/2013
Time        : 08:49:41
Type        : Information
Source      : acvpnagent
Description : Current Preference Settings:
ServiceDisable: false
CertificateStoreOverride: false
CertificateStore: All
ShowPreConnectMessage: false
AutoConnectOnStart: false
MinimizeOnConnect: true
LocalLanAccess: false
AutoReconnect: true
AutoReconnectBehavior: DisconnectOnSuspend
UseStartBeforeLogon: false
AutoUpdate: true
RSASecurIDIntegration: Automatic
WindowsLogonEnforcement: SingleLocalLogon
WindowsVPNEstablishment: LocalUsersOnly
ProxySettings: Native
AllowLocalProxyConnections: true
PPPExclusion: Disable
PPPExclusionServerIP:
AutomaticVPNPolicy: false
TrustedNetworkPolicy: Disconnect
UntrustedNetworkPolicy: Connect
TrustedDNSDomains:
TrustedDNSServers:
AlwaysOn: false
ConnectFailurePolicy: Closed
AllowCaptivePortalRemediation: false
CaptivePortalRemediationTimeout: 5
ApplyLastVPNLocalResourceRules: false
AllowVPNDisconnect: true
EnableScripting: false
TerminateScriptOnNextEvent: false
EnablePostSBLOnConnectScript: true
AutomaticCertSelection: true
RetainVpnOnLogoff: false
UserEnforcement: SameUserOnly
EnableAutomaticServerSelection: false
AutoServerSelectionImprovement: 20
AutoServerSelectionSuspendTime: 4
AuthenticationTimeout: 12
SafeWordSofTokenIntegration: false
AllowIPsecOverSSL: false
ClearSmartcardPin: true
IPProtocolSupport: IPv4,IPv6
AllowManualHostInput: true
BlockUntrustedServers: true
PublicProxyServerAddress:
Date        : 07/23/2013
Time        : 08:49:41
Type        : Error
Source      : acvpnagent
Description : Function: CSocketSupport::ipv6EnabledOnVA
File: .\IPC\SocketSupport_win.cpp
Line: 284
Invoked Function: CSocketSupport::ipv6EnabledOnVA
Return Code: 2 (0x00000002)
Description: cannot open VPNVA Enum registry key (VA driver not installed?)
Date        : 07/23/2013
Time        : 08:49:41
Type        : Error
Source      : acvpnagent
Line: 284
Date        : 07/23/2013
Time        : 08:49:41
Type        : Information
Source      : acvpnagent
Description : Function: CCvcConfig::readConfigParamFromFile
File: .\vpnconfig.cpp
Line: 5824
The specified configuration file for MUS service does not exist
Date        : 07/23/2013
Time        : 08:49:41
Type        : Information
Source      : acvpnagent
Description : Function: CThread::createThread
File: .\Utility\Thread.cpp
Line: 238
The thread (0x00001F84) has been successfully created.
Date        : 07/23/2013
Time        : 08:49:41
Type        : Information
Source      : acvpnagent
Description : Cisco AnyConnect Secure Mobility Client Agent started, version 3.1.04059
Date        : 07/23/2013
Time        : 08:49:41
Type        : Information
Source      : acvpnagent
Description : Function: CInterfaceRouteMonitorCommon::logInterfaces
File: .\Routing\InterfaceRouteMonitorCommon.cpp
Line: 477
IP Address Interface List:
FE80:0:0:0:DDA0:24CA:FE35:4D19
148.110.133.126
FE80:0:0:0:19A3:961F:C11C:3724
192.168.164.1
FE80:0:0:0:80B3:F3CD:CA44:952E
169.254.149.46
Date        : 07/23/2013
Time        : 08:49:45
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:49:45
Type        : Error
Source      : acvpnagent
Line: 126
Date        : 07/23/2013
Time        : 08:49:45
Type        : Error
Source      : acvpnagent
Line: 1422
Date        : 07/23/2013
Time        : 08:49:45
Type        : Error
Source      : acvpnagent
Line: 187
Date        : 07/23/2013
Time        : 08:49:45
Type        : Error
Source      : acvpnagent
Line: 82
Date        : 07/23/2013
Time        : 08:49:45
Type        : Warning
Source      : acvpnagent
Line: 1017
Date        : 07/23/2013
Time        : 08:49:45
Type        : Warning
Source      : acvpnagent
Line: 195
Date        : 07/23/2013
Time        : 08:49:45
Type        : Information
Source      : acvpnagent
Line: 246
Date        : 07/23/2013
Time        : 08:49:45
Type        : Information
Source      : acvpnagent
Line: 100
Date        : 07/23/2013
Time        : 08:49:45
Type        : Information
Source      : acvpnagent
AutoReconnect: true
AutoUpdate: true
TrustedDNSDomains:
TrustedDNSServers:
AlwaysOn: false
Date        : 07/23/2013
Time        : 08:49:45
Type        : Error
Source      : acvpnagent
Line: 284
Date        : 07/23/2013
Time        : 08:49:45
Type        : Error
Source      : acvpnagent
Line: 284
Date        : 07/23/2013
Time        : 08:49:45
Type        : Information
Source      : acvpnagent
Line: 5824
Date        : 07/23/2013
Time        : 08:49:45
Type        : Information
Source      : acvpnagent
Line: 238
The thread (0x00001F20) has been successfully created.
Date        : 07/23/2013
Time        : 08:49:45
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:49:45
Type        : Information
Source      : acvpnagent
Line: 477
148.110.133.126
192.168.164.1
169.254.149.46
Date        : 07/23/2013
Time        : 08:49:48
Type        : Information
Description : Function: SetInheritACLsFromParent
File: .\ACLManager.cpp
Line: 31
Attributes for C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\ are 0x2010
Date        : 07/23/2013
Time        : 08:49:48
Type        : Information
Line: 56
Obtaining ACLs for directory C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\
Date        : 07/23/2013
Time        : 08:49:48
Type        : Information
Line: 31
Attributes for C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\CustomerExperienceFeedback are 0x2010
Date        : 07/23/2013
Time        : 08:49:48
Type        : Information
Line: 56
Obtaining ACLs for directory C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\CustomerExperienceFeedback\
Date        : 07/23/2013
Time        : 08:49:48
Type        : Information
Line: 31
Attributes for C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\Help are 0x2010
Date        : 07/23/2013
Time        : 08:49:48
Type        : Information
Line: 56
Obtaining ACLs for directory C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\Help\
Date        : 07/23/2013
Time        : 08:49:48
Type        : Information
Line: 31
Attributes for C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\l10n are 0x2010
Date        : 07/23/2013
Time        : 08:49:48
Type        : Information
Line: 56
Obtaining ACLs for directory C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\l10n\
Date        : 07/23/2013
Time        : 08:49:48
Type        : Information
Line: 31
Attributes for C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\Profile are 0x2010
Date        : 07/23/2013
Time        : 08:49:48
Type        : Information
Line: 56
Obtaining ACLs for directory C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\Profile\
Date        : 07/23/2013
Time        : 08:49:48
Type        : Information
Line: 31
Attributes for C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\Script are 0x2010
Date        : 07/23/2013
Time        : 08:49:48
Type        : Information
Line: 56
Obtaining ACLs for directory C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\Script\
Date        : 07/23/2013
Time        : 08:49:49
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:49:50
Type        : Error
Source      : acvpnagent
Line: 126
Date        : 07/23/2013
Time        : 08:49:50
Type        : Error
Source      : acvpnagent
Line: 1422
Date        : 07/23/2013
Time        : 08:49:50
Type        : Error
Source      : acvpnagent
Line: 187
Date        : 07/23/2013
Time        : 08:49:50
Type        : Error
Source      : acvpnagent
Line: 82
Date        : 07/23/2013
Time        : 08:49:50
Type        : Warning
Source      : acvpnagent
Line: 1017
Date        : 07/23/2013
Time        : 08:49:50
Type        : Warning
Source      : acvpnagent
Line: 195
Date        : 07/23/2013
Time        : 08:49:50
Type        : Information
Source      : acvpnagent
Line: 246
Date        : 07/23/2013
Time        : 08:49:50
Type        : Information
Source      : acvpnagent
Line: 100
Date        : 07/23/2013
Time        : 08:49:50
Type        : Information
Source      : acvpnagent
AutoReconnect: true
AutoUpdate: true
TrustedDNSDomains:
TrustedDNSServers:
AlwaysOn: false
Date        : 07/23/2013
Time        : 08:49:50
Type        : Information
Source      : acvpnagent
Line: 5824
Date        : 07/23/2013
Time        : 08:49:50
Type        : Information
Source      : acvpnagent
Line: 238
The thread (0x000016C0) has been successfully created.
Date        : 07/23/2013
Time        : 08:49:50
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:49:50
Type        : Information
Source      : acvpnagent
Line: 477
148.110.133.126
192.168.164.1
169.254.149.46
Date        : 07/23/2013
Time        : 08:50:10
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:50:11
Type        : Error
Source      : acvpnagent
Line: 126
Date        : 07/23/2013
Time        : 08:50:11
Type        : Error
Source      : acvpnagent
Line: 1422
Date        : 07/23/2013
Time        : 08:50:11
Type        : Error
Source      : acvpnagent
Line: 187
Date        : 07/23/2013
Time        : 08:50:11
Type        : Error
Source      : acvpnagent
Line: 82
Date        : 07/23/2013
Time        : 08:50:11
Type        : Warning
Source      : acvpnagent
Line: 1017
Date        : 07/23/2013
Time        : 08:50:11
Type        : Warning
Source      : acvpnagent
Line: 195
Date        : 07/23/2013
Time        : 08:50:11
Type        : Information
Source      : acvpnagent
Line: 246
Date        : 07/23/2013
Time        : 08:50:11
Type        : Information
Source      : acvpnagent
Line: 100
Date        : 07/23/2013
Time        : 08:50:11
Type        : Information
Source      : acvpnagent
AutoReconnect: true
AutoUpdate: true
TrustedDNSDomains:
TrustedDNSServers:
AlwaysOn: false
Date        : 07/23/2013
Time        : 08:50:11
Type        : Information
Source      : acvpnagent
Line: 5824
Date        : 07/23/2013
Time        : 08:50:11
Type        : Information
Source      : acvpnagent
Line: 238
The thread (0x00001F34) has been successfully created.
Date        : 07/23/2013
Time        : 08:50:11
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:50:11
Type        : Information
Source      : acvpnagent
Line: 477
148.110.133.126
192.168.164.1
169.254.149.46
Date        : 07/23/2013
Time        : 08:50:19
Type        : Information
Source      : acvpnui
Description : Cisco AnyConnect Secure Mobility Client GUI started, version 3.1.04059
Date        : 07/23/2013
Time        : 08:50:20
Type        : Information
Source      : acvpnui
Description : Initializing vpnapi version 3.1.04059 ().
Date        : 07/23/2013
Time        : 08:50:21
Type        : Information
Source      : acvpnui
Line: 246
Date        : 07/23/2013
Time        : 08:50:21
Type        : Information
Source      : acvpnui
Line: 100
Date        : 07/23/2013
Time        : 08:50:21
Type        : Warning
Source      : acvpnui
Description : Function: ClientIfcBase::getCurrentState
File: .\ClientIfcBase.cpp
Line: 2058
API service not ready
Date        : 07/23/2013
Time        : 08:50:21
Type        : Information
Source      : acvpnui
AutoReconnect: true
AutoUpdate: true
TrustedDNSDomains:
TrustedDNSServers:
AlwaysOn: false
Date        : 07/23/2013
Time        : 08:50:21
Type        : Warning
Source      : acvpnui
Line: 195
com.cisco.anyconnect.nam.api
Date        : 07/23/2013
Time        : 08:50:21
Type        : Information
Source      : acvpnui
Description : Function: L2Api::attach
File: .\L2Api.cpp
Line: 87
The NAM/L2 Api could not be found or failed to load, skipping.
Date        : 07/23/2013
Time        : 08:50:21
Type        : Warning
Source      : acvpnui
Line: 195
com.cisco.anyconnect.websecurity.api
Date        : 07/23/2013
Time        : 08:50:21
Type        : Information
Source      : acvpnui
Description : Function: SSApi::attach
File: ..\common\SSApi.cpp
Line: 51
The Web Security API could not be found or failed to load, skipping.
Date        : 07/23/2013
Time        : 08:50:21
Type        : Error
Source      : acvpnui
Description : Function: MFDartBox::getDARTInstallDir
File: .\MFDartBox.cpp
Line: 332
Invoked Function: MsiEnumProductsExW
Return Code: 259 (0x00000103)
Description: No more data is available.
Date        : 07/23/2013
Time        : 08:50:21
Type        : Warning
Source      : acvpnui
Description : Function: ClientIfcBase::getStats
Line: 1723
Called when API service not ready.
Date        : 07/23/2013
Time        : 08:50:22
Type        : Error
Source      : acvpnui
Description : Function: CSocketTransport::connectTransport
File: .\IPC\SocketTransport.cpp
Line: 981
Invoked Function: ::WSAConnect
Return Code: 10061 (0x0000274D)
Description: No connection could be made because the target machine actively refused it.
Date        : 07/23/2013
Time        : 08:50:22
Type        : Error
Source      : acvpnui
Description : Function: CIpcTransport::connectIpc
File: .\IPC\IPCTransport.cpp
Line: 252
Invoked Function: CSocketTransport::connectTransport
Return Code: -31588340 (0xFE1E000C)
Description: SOCKETTRANSPORT_ERROR_CONNECT
Date        : 07/23/2013
Time        : 08:50:22
Type        : Error
Source      : acvpnui
Description : Function: CIpcTransport::terminateIpcConnection
Line: 404
Invoked Function: CSocketTransport::writeSocketBlocking
Return Code: -31588319 (0xFE1E0021)
Description: SOCKETTRANSPORT_ERROR_NO_SOCKET_HANDLE:The socket transport does not possess a valid socket handle.
Date        : 07/23/2013
Time        : 08:50:22
Type        : Error
Source      : acvpnui
Description : Function: ApiIpc::initIpc
File: .\ApiIpc.cpp
Line: 423
Invoked Function: CIpcTransport::connectIpc
Date        : 07/23/2013
Time        : 08:50:22
Type        : Error
Source      : acvpnui
Description : Function: ApiIpc::initiateAgentConnection
File: .\ApiIpc.cpp
Line: 336
Invoked Function: ApiIpc::initIpc
Date        : 07/23/2013
Time        : 08:50:22
Type        : Error
Source      : acvpnui
Description : Function: ApiIpc::run
File: .\ApiIpc.cpp
Line: 570
Invoked Function: ApiIpc::initiateAgentConnection
Date        : 07/23/2013
Time        : 08:50:22
Type        : Error
Source      : acvpnui
Description : Function: ClientIfcBase::attach
Line: 606
Client failed to attach.
Date        : 07/23/2013
Time        : 08:50:25
Type        : Error
Source      : acvpnui
Description : Function: CMainFrame::OnCreate
File: .\mainfrm.cpp
Line: 342
Invoked Function: The VPN service is not responding or available.
Date        : 07/23/2013
Time        : 08:50:25
Type        : Information
Source      : acvpnui
Description : Function: ClientIfcBase::detach
Line: 438
Shutting down vpnapi
Date        : 07/23/2013
Time        : 08:50:25
Type        : Error
Source      : acvpnui
Description : Function: ConnectMgr::activateConnectEvent
File: .\ConnectMgr.cpp
Line: 1352
NULL object. Cannot establish a connection at this time.
Date        : 07/23/2013
Time        : 08:50:25
Type        : Information
Source      : acvpnui
Description : Cisco AnyConnect Secure Mobility Client GUI exiting, version 3.1.04059 , return code 0 [0x00000000]
Date        : 07/23/2013
Time        : 08:51:12
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:51:12
Type        : Error
Source      : acvpnagent
Line: 126
Date        : 07/23/2013
Time        : 08:51:12
Type        : Error
Source      : acvpnagent
Line: 1422
Date        : 07/23/2013
Time        : 08:51:12
Type        : Error
Source      : acvpnagent
Line: 187
Date        : 07/23/2013
Time        : 08:51:12
Type        : Error
Source      : acvpnagent
Line: 82
Date        : 07/23/2013
Time        : 08:51:12
Type        : Warning
Source      : acvpnagent
Line: 1017
Date        : 07/23/2013
Time        : 08:51:12
Type        : Warning
Source      : acvpnagent
Line: 195
Date        : 07/23/2013
Time        : 08:51:12
Type        : Information
Source      : acvpnagent
Line: 246
Date        : 07/23/2013
Time        : 08:51:12
Type        : Information
Source      : acvpnagent
Line: 100
Date        : 07/23/2013
Time        : 08:51:12
Type        : Information
Source      : acvpnagent
AutoReconnect: true
AutoUpdate: true
TrustedDNSDomains:
TrustedDNSServers:
AlwaysOn: false
Date        : 07/23/2013
Time        : 08:51:12
Type        : Information
Source      : acvpnagent
Line: 5824
Date        : 07/23/2013
Time        : 08:51:12
Type        : Information
Source      : acvpnagent
Line: 238
The thread (0x0000162C) has been successfully created.
Date        : 07/23/2013
Time        : 08:51:12
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:51:12
Type        : Information
Source      : acvpnagent
Line: 477
148.110.133.126
192.168.164.1
169.254.149.46
Date        : 07/23/2013
Time        : 08:52:13
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:52:13
Type        : Error
Source      : acvpnagent
Line: 126
Date        : 07/23/2013
Time        : 08:52:13
Type        : Error
Source      : acvpnagent
Line: 1422
Date        : 07/23/2013
Time        : 08:52:13
Type        : Error
Source      : acvpnagent
Line: 187
Date        : 07/23/2013
Time        : 08:52:13
Type        : Error
Source      : acvpnagent
Line: 82
Date        : 07/23/2013
Time        : 08:52:13
Type        : Warning
Source      : acvpnagent
Line: 1017
Date        : 07/23/2013
Time        : 08:52:13
Type        : Warning
Source      : acvpnagent
Line: 195
Date        : 07/23/2013
Time        : 08:52:13
Type        : Information
Source      : acvpnagent
Line: 246
Date        : 07/23/2013
Time        : 08:52:13
Type        : Information
Source      : acvpnagent
Line: 100
Date        : 07/23/2013
Time        : 08:52:13
Type        : Information
Source      : acvpnagent
AutoReconnect: true
AutoUpdate: true
TrustedDNSDomains:
TrustedDNSServers:
AlwaysOn: false
Date        : 07/23/2013
Time        : 08:52:13
Type        : Information
Source      : acvpnagent
Line: 5824
Date        : 07/23/2013
Time        : 08:52:13
Type        : Information
Source      : acvpnagent
Line: 238
The thread (0x00001240) has been successfully created.
Date        : 07/23/2013
Time        : 08:52:13
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:52:13
Type        : Information
Source      : acvpnagent
Line: 477
148.110.133.126
192.168.164.1
169.254.149.46
Date        : 07/23/2013
Time        : 08:53:14
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:53:14
Type        : Error
Source      : acvpnagent
Line: 126
Date        : 07/23/2013
Time        : 08:53:14
Type        : Error
Source      : acvpnagent
Line: 1422
Date        : 07/23/2013
Time        : 08:53:14
Type        : Error
Source      : acvpnagent
Line: 187
Date        : 07/23/2013
Time        : 08:53:14
Type        : Error
Source      : acvpnagent
Line: 82
Date        : 07/23/2013
Time        : 08:53:14
Type        : Warning
Source      : acvpnagent
Line: 1017
Date        : 07/23/2013
Time        : 08:53:14
Type        : Warning
Source      : acvpnagent
Line: 195
Date        : 07/23/2013
Time        : 08:53:14
Type        : Information
Source      : acvpnagent
Line: 246
Date        : 07/23/2013
Time        : 08:53:14
Type        : Information
Source      : acvpnagent
Line: 100
Date        : 07/23/2013
Time        : 08:53:14
Type        : Information
Source      : acvpnagent
AutoReconnect: true
AutoUpdate: true
TrustedDNSDomains:
TrustedDNSServers:
AlwaysOn: false
Date        : 07/23/2013
Time        : 08:53:14
Type        : Information
Source      : acvpnagent
Line: 5824
Date        : 07/23/2013
Time        : 08:53:14
Type        : Information
Source      : acvpnagent
Line: 238
The thread (0x00001CC4) has been successfully created.
Date        : 07/23/2013
Time        : 08:53:14
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:53:14
Type        : Information
Source      : acvpnagent
Line: 477
148.110.133.126
192.168.164.1
169.254.149.46
Date        : 07/23/2013
Time        : 08:54:15
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:54:15
Type        : Error
Source      : acvpnagent
Line: 126
Date        : 07/23/2013
Time        : 08:54:15
Type        : Error
Source      : acvpnagent
Line: 1422
Date        : 07/23/2013
Time        : 08:54:15
Type        : Error
Source      : acvpnagent
Line: 187
Date        : 07/23/2013
Time        : 08:54:15
Type        : Error
Source      : acvpnagent
Line: 82
Date        : 07/23/2013
Time        : 08:54:15
Type        : Warning
Source      : acvpnagent
Line: 1017
Date        : 07/23/2013
Time        : 08:54:15
Type        : Warning
Source      : acvpnagent
Line: 195
Date        : 07/23/2013
Time        : 08:54:16
Type        : Information
Source      : acvpnagent
Line: 246
Date        : 07/23/2013
Time        : 08:54:16
Type        : Information
Source      : acvpnagent
Line: 100
Date        : 07/23/2013
Time        : 08:54:16
Type        : Information
Source      : acvpnagent
AutoReconnect: true
AutoUpdate: true
TrustedDNSDomains:
TrustedDNSServers:
AlwaysOn: false
Date        : 07/23/2013
Time        : 08:54:16
Type        : Information
Source      : acvpnagent
Line: 5824
Date        : 07/23/2013
Time        : 08:54:16
Type        : Information
Source      : acvpnagent
Line: 238
The thread (0x00001304) has been successfully created.
Date        : 07/23/2013
Time        : 08:54:16
Type        : Information
Source      : acvpnagent
Date        : 07/23/2013
Time        : 08:54:16
Type        : Information
Source      : acvpnagent
Line: 477
148.110.133.126
192.168.164.1
169.254.149.46
stephan.ochs
There seem to be much more problems with 3.1.04049
Especially with certificate authentication.
I opened some TAC cases.
Try 3.1.04063 that came out at 07-24-13.
TAC said that there are some fixes in it...
Hi.
Thank you very much for your help.
I did try the latest version but no luck, it seems not to solve the issue.
Any other idea?
Did you ever find a resolution to this issue?  I'm seeing something very similar with a few people.  I am running the same version, 3.1.04059
