Problems with Cisco AnyConnect Secure Mobility Client
topl
I'm using Windows 10 with Cisco AnyConnect version 4.9.05042.
In EventViewer I get a bunch of errors related to Cisco.
The first one is this:
Function: XmlParser::invokeParser
File: c:\temp\build\thehoff\orion_mr50.794481233569\orion_mr5\vpn\common\xml\xmlparser.cpp
Line: 199
Invoked Function: ISAXXMLReader::parse
Return Code: -2146697210 (0x800C0006)
Description: The system cannot locate the object specified.
Followed by
Function: CPhoneHomeStatus::LoadStatusFromConfigFile
File: c:\temp\build\thehoff\orion_mr50.794481233569\orion_mr5\phonehome\phonehomepluginimp.cpp
Line: 289
Invoked Function: XmlParser::parseFile
Return Code: -33554423 (0xFE000009)
Description: GLOBAL_ERROR_UNEXPECTED
Can someone explain what the hell is happening, because I don't even have catalog c:\temp\build\...?
Where to look and how to fix it?
tvotna
AnyConnect always produces tons of meaningless errors because developers haven't prioritized messages properly and the product doesn't have options to suppress noise in logs. No need to worry about unless it doesn't work.
Hi @topl
 please take a look at:
 Cisco AnyConnect Secure Mobility Client Software for Windows and Cisco Secure Client Software for Windows Privilege Escalation Vulnerability special attention to First Fixed in 4.10MR7 (4.10.07061).
Release Notes for Cisco AnyConnect Secure Mobility Client, Release 4.10 special attention to the New Features.
Hope this helps !!!
