Problems with IPSec termination on Cisco836
michael.schwarz
Hello I built a VPN with a Cisco836 router as concentrator for two direct IPSec connection with fixed addresse, one IPSec connection from a dynamic address and one IPSec connection from a Cisco VPN Client. All connection should work over a PKI infrastrucure with x509 certificates.
With the configuration below all IPSec connections work fine only the VPNClient connection does not work. If I configure the access-list 101 with permit ip any any then all IPSec connection work but only over the VPNClient profile and not over their own profile and access-list????!!!!
If I configure additional XAUTH for VPNClient connection then the also the other IPSec connection want to authenticate by XAUTH???!!!
Is anybody there who can say me the mistake of these configuration below?
Configuration of Cisco836 as VPN concentrator:
!C836-K9O3S8Y6-M, Version 12.3(2)XA
username xxxxxxx password xxxxxxxx
aaa new-model
aaa authentication login ClientAuth local
aaa authorization network ClientAuth local
aaa session-id common
crypto isakmp policy 10
encr 3des
hash md5
group 2
crypto isakmp policy 40
encr 3des
group 2
crypto isakmp identity dn
crypto isakmp keepalive 10 3
crypto isakmp client configuration group xxxxxxxx
pool vpnpool
crypto ipsec transform-set 3desMD5 esp-3des esp-md5-hmac
crypto dynamic-map ISPpeers 30
set transform-set 3desMD5
match address 122
crypto dynamic-map VPNClients 40
match address 101
!crypto map zentrale client authentication list ClientAuth
crypto map zentrale isakmp authorization list ClientAuth
crypto map zentrale client configuration address respond
crypto map zentrale 10 ipsec-isakmp
set peer xxx.xxx.xxx.xxx
match address 120
crypto map zentrale 20 ipsec-isakmp
match address 121
crypto map zentrale 30 ipsec-isakmp dynamic ISPpeers
crypto map zentrale 40 ipsec-isakmp dynamic VPNClients
interface Dialer1
ip address negotiated
ip mtu 1300
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer remote-name dsl
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxxxxxx
ppp chap password xxxxxxxx
crypto map zentrale
ip local pool vpnpool 172.31.1.1 172.31.1.10
access-list 101 permit ip 10.110.10.0 0.0.0.255 172.31.1.0 0.0.0.255
access-list 120 permit ip host 172.25.128.3 host 172.25.1.1
access-list 121 permit ip host 172.29.128.3 host 172.29.1.1
access-list 122 permit ip 10.110.10.0 0.0.0.255 10.120.10.0 0.0.0.255
gfullage
If you have both dynamic and fixed tunnels terminating on a hub router, with both VPn clients and L2L tunnels terminating, you need to use ISAKMP Profiles to separate the two.
There's a sample config here:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008032cd24.shtml
in which there is a IOS hub router (your 836), a PIX w spoke with a L2L config, a PIX set up as an EzVPN client (dynamic IP address), and a VPN client configuration, similar to what you have set up.
Create an ISAKMP Profile for each tunnel type, and use the "match identity" command under these to map the specific remote tunnel attributes.
For example, you can do a "match identity address x.x.x.x" for your LAN-to-LAN tunnel because you know the address it will be coming from.
Use a "match identity group " for your VPN clients, where is the group name configured in the VPN client profile. Under that profile you can then add your "isakmp client authen/author" type commands.
Define a similar ISAKMP Profile with another "match identity group " where is the group name configured on the remote IPSec device with a dynamic IP address.
Then you just define a crypto map as normal, and map it to two instances of a dynamic crypto map, both pointing to your two "match identity group ..." ISAKMP Profiles. The router will pick the best match, assign it to teh most specific ISAKMP Profile and take all the tunnel's attributes from that.
