Problems with Sysprep and Cisco VPN Client v4.0.4
adamlaubach
I ma having difficulty with Sysprep and the Cisco VPN Client ver 4.0.4.
When I install the client and then run Sysprep, then the normal sysprep reboot
process takes a lot longer. Sysprep goes through it's normal routine, but
when it gets to the section that says it's configuring the network, it sits there for about 5-10 minutes before completing. We have had no problems with ealier versions of the client, but when I install this version on the image sysprep exhibits this behaviour. Anyone ever seen this?
mostiguy
Level 6
Level 6
We have not seen this with 4.03f
Has anyone else seen this issue?
I've just seen this issue with the Cisco VPN 4.6 client. Did you ever get a resolution? I would be interested to see what you have found out.
We are still having this issue, even after putting 4.6 on out image. I am sure this is when it is installing the determinstic network enhancer, just not sure why it is taking so long. Thinking about calling in a ticket but haven't yet since it is more of an inconvenience than anything.
