Problems with VPN3005 OS 4.1.7.F and Movian Client
peedee
I have a VPN Concentrator 3005 which has been running on OS version 4.1.3. I have two types of client which connect with IPSEC/IKE - Cisco clients on Windows XP & Movian VPN clients on Windows CE.
Due to a recently discovered security issue with this version of the OS I upgraded to version 4.1.7F.
After upgrading the 3005 the Cisco clients continued to work fine but the Movian clients were unable to establish a connection. Looking at the event log I notice that both clients complete Phase 1. However after this the Cisco client matches the SA and authenticates (IPSec SA Proposal # 1, Transform # 1 acceptable Matches global IPSec SA entry # 4 Proposal (ESP-3DES-SHA) etc. etc.)
Whereas the movian client does not (see below): any ideas as why this is happening with the new OS version?
7417 06/23/2005 09:52:54.140 SEV=4 IKE/119 RPT=11 10.63.197.192
Group [labuser] User [netPAD-guy-1924V]
PHASE 1 COMPLETED
7418 06/23/2005 09:52:54.140 SEV=6 IKE/121 RPT=11 10.63.197.192
Keep-alive type for this connection: None
7419 06/23/2005 09:52:54.140 SEV=6 IKE/122 RPT=7 10.63.197.192
Keep-alives configured on but peer does not support keep-alives (type = None)
7420 06/23/2005 09:52:54.140 SEV=7 IKEDBG/82 RPT=11 10.63.197.192
Starting phase 1 rekey timer: 2700000 (ms)
7422 06/23/2005 09:52:54.140 SEV=9 IKEDBG/0 RPT=702 10.63.197.192
IKE SA AM:86c2b3ae rcv'd Terminate: state AM_ACTIVE
flags 0x00413041, refcnt 1, tuncnt 1
7425 06/23/2005 09:52:54.140 SEV=9 IKEDBG/0 RPT=703
sending delete/delete with reason message
7426 06/23/2005 09:52:54.140 SEV=6 IKE/0 RPT=11 10.63.197.192
Removing peer from correlator table failed, no match!
7428 06/23/2005 09:52:54.150 SEV=9 IKEDBG/0 RPT=704 10.63.197.192
IKE SA AM:86c2b3ae terminating:
flags 0x01413001, refcnt 0, tuncnt 0
7430 06/23/2005 09:52:54.150 SEV=9 IKEDBG/0 RPT=705
7431 06/23/2005 09:52:54.150 SEV=9 IKEDBG/0 RPT=706 10.63.197.192
constructing blank hash
7432 06/23/2005 09:52:54.150 SEV=9 IKEDBG/0 RPT=707
constructing IKE delete payload
7433 06/23/2005 09:52:54.150 SEV=9 IKEDBG/0 RPT=708 10.63.197.192
constructing qm hash
7434 06/23/2005 09:52:54.150 SEV=8 IKEDBG/81 RPT=278 10.63.197.192
SENDING Message (msgid=8a595645) with payloads :
HDR + HASH (8) + DELETE (12)
total length : 80
7436 06/23/2005 09:52:54.150 SEV=4 AUTH/23 RPT=7 10.63.197.192
User [netPAD-guy-1924V] Group [labuser] disconnected: duration: 0:00:00
7447 06/23/2005 09:52:58.320 SEV=8 IKEDBG/96 RPT=18 10.63.197.192
Received encrypted packet with no matching SA, dropping
5 Replies 5
haiyingwei
We had same problem as you after we upgraded concentrator from 4.1.5.B to 4.1.7.F. Our Movian vpn client dropped connection after phase 1 completed.
Did you find work around for your movian client or you downgrade concentrator's OS?
Sadly I had to downgrade the concentrators OS. I have seen that AnthaVPN are producing the latest version of the client - but this does not run on our client hardware! So at the moment we are stuck on the old OS.
mlew
Same here, but with version 4.7.1 on a 3030
Can you run the built-in VPNs on PPC and Palm to connect to a VPN 3000?
lrzvpn
CSCsa65275
This issue is actually a problem with all non-Unity clients. Movian has the ability to be either Unity or pre-Unity -- Unity works fine.
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_1/417ecn3k.htm
We changed the Movian profile from "Cisco VPN 3000" to "Cisco Unity Client", reentered the IKE and IPsec Parameters and the Client was able to connect again.
We noticed a different connection Type. (IPsec over TCP vs IPsec)
AWESOME! THANK YOU, I OWE YOU ONE.
Marcelo
