Quick question about 'local network' for ASA 5500 LAN to LAN
cweatherford
I have to setup access for a support vendor that needs access to just a few IP addresses in my datacenter but all of my branch locations. In the LAN to LAN setup can I enter more than one IP and subnets?
Thanks!
Chad
rizwanr74
Level 7
Level 7
HI Chad,
"In the LAN to LAN setup can I enter more than one IP and subnets?"
Sure you can, if you are planing to setup land to land IPSec tunne, it is your no-nat and crypto acl can be used to control what are allowed and what not over the tunnel itself.
However if you planing to use a remote-access tunnel instead, it is your "vpn-filter value" and associate it with an ACL and in the example below group name is set as "filter"
group-policy filter internal
group-policy filter attributes
 vpn-filter value 103
Reference:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808c9a87.shtml
Rizwan Rafeek
rizwanr74
Level 7
Level 7
HI Chad,
Reference:
Rizwan Rafeek
Thanks Rizwan!
