RDP Traffic problem with remote vpn
arshad_cisco86
Kindly find the configuration ,
access-list RDP_WMS standard permit host 20.5.6.1
ip local pool POOL1 xx.xxx.x.xx-xx.xxx.x.xx mask 255.255.255.0
group-policy metro internal
group-policy metro attributes
 dns-server value 20.5.5.58 20.5.5.46
 vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value RDP_WMS
username user1 password 123456 priv 0
username user1 attributes
 vpn-group-policy metro
 vpn-simultaneous-logins 1
 service-type remote-access
nat (inside) 0 access-list nonat
access-list nonat extended permit ip any 20.0.0.0 255.0.0.0
tunnel-group metro type remote-access
tunnel-group metro general-attributes
 address-pool POOL1
 default-group-policy metro
tunnel-group metro ipsec-attributes
 pre-shared-key 123456
Arshad AYub
pjain2
is 20.5.6.1 the ip address of the host to which you are trying to RDP into?
if so, please correct your nat exemption access-list:
access-list nonat extended permit ip 20.0.0.0 255.0.0.0 any
Dear pjain2 ,
I did according ur suggestion , still same problem .
Shall we checkout traffic of 3389 thru remote vpn
Arshad Ayub
please take captures on the inside interface of the ASA
capture capin interface inside match ip host <assigned ip> host 20.5.6.1
also you are trying to rdp through ip address or the name?
EARLIER ISSUE HAS BEEN RESOLVED
PLZ SUGGEST FOR BELOW
2.i want packet-tracer for outside to inside NAT
