Remote Management for DPC3925
alete89
Hello Everyone, thanks for reading. The picture shows my unsuccessful try to configure remote access to router configuration from outside (www). This isn't working.
I use portforwarding daily and works well, i cannot understand why this does not. any advice?
Thanks!
I think your 3925 router needs a static IP address to set up port forwarding. Check if the port you are forwarding is actually open and reachable with this online tool:
http://www.yougetsignal.com/tools/open-ports/
Hi gpauwen, thanks for your reply.
I don't get what you are trying to say.
Independently of remote management, portforwarding for ssh, web server , works just fine to different local machines in my network. That is configured in "application and gaming - port forwarding"
but, this other setting isn't working properly.
UPDATE: suddenly (this is embarrassment) it started working in one specific port. So thanks!!!
I think it maybe could be that restart was needed.
good to hear that it is working. Which port are you using, 4489 ?
