Routing between dmz's and best practices
Hi all Pros,
                   I am looking for best practices of routing between dmzs and configuration sample. In the diagram attached, I have all my vpn routers(site-2-site, and remote access) in their own dmz. Now, all the customer connected through the vpn can access the corporate network at for example:10.10.0.0/16, but can't access my dmzs yet! The plan was that customer will only use 192.168.9/24 to connect to the VPN. Once connected, all the traffic will go through 192.168.6.0/24- At the moment they can connected to the corporate network with this setup-.
1. To get routing working for dmz200,300.. I thinking to hairpin(send trattic back to same interface) traffic for these dmzs and set ACL permit traffic from vpn-dmz.
Any comments and suggestion are more than welcome,
Thanks in advance,
Jean Paul
mulatif
Hi Jean,
If you want the DMZ to talk to each other then why the use of different DMZs in the first place ? Is it because these are different customer and you want to control the traffic flow between the customers ?
To answer your questions, As long as DMZ 200\300, VPN-DMZ are different logical\physical interfaces you should be able to route traffic between them. What is the issue that you are running into ?
If it turns out to be  a complex issue then it might be quicker for you to open a TAC case.
Naman
