Running login script after AnyConnect VPN Connection
snowmizer
Is there a way (similar to the application launcher on the IPSec client) to launch a login script after establishing a VPN connection? After a user connects to the VPN from the AnyConnect client I need to be able to run a login script to map drives. I looked at the ASDM but don't see anywhere that it looks like this would be configured. I figured I'd check to make sure I'm not missing anything.
We're running ASA IOS v8.2(2), ASDM 6.2(5).
Thanks.
