SA520W Port Forwarding - Help
Dhostetter1023
I’m new to this so please excuse me if this seems like a silly / basic question.
We recently installed a new SA520W. We have 5 static ip address assigned to my company, X.X.X.120 thru .124.
We have set up X.X.X.121 as our WAN port and 192.168.1.X as our LAN addresses.
Everything is working perfectly.
Now we would like to access our DVR system on our LAN via one of our External Static IP’s, let’s say X.X.X.122.
The DVR’s LAN address is 192.168.1.20. I need to have port 8080 used to connect to the DVR.
How would I go about configuring the SA520W so I can access the DVR from the internet?
Any help would be appreciated!
Dave
Pawan Sharma
Below is the process to perform a static NAT on SA520W -
Go to Firewall --> Services --> Custom Service Configuration.
Create a service for the ports used by your DVR, Then -
the attached snapshot would help you configure the port forwarding for your service.
Pawan Sharma
http://www.ebrahma.com
Pawan Sharma
https://itgears.io
