Segregate calls based on incoming signals
sajin9231
We use 1 PRI line for voucher transactions. The current setup is whenever a POS(Point of Sale) terminal connects to the PRI, its routed to an application server via a Cisco Access Server. Is it possible to connect another application server through the same PRI line such that both work simultaneously? Note that both application servers run different applications and the calls has to be filtered and routed correspondingly.
paolo bevilacqua
Yes, it is possible. You will need to engage a reputable newtok engineer for the proper configuration to be made.
Can you please let me know how to implement it?
