Setting up a GRE using IPSEC on Cisco 7604
ggladney
To establish s secure tunnel using GRE with IPSec do I need to add a SPA-IPSEC module to my 7604 chassis?  Thanks in advance for any help?
Gary
Jennifer Halim
Yes, to terminate VPN (inc. GRE over IPSec) on 7604, you would need to have the SPA-IPSEC module as the IOS is not capable of terminating VPN except if you configure VPN Client to manage the 7604 itself. Other than that, if you would like to pass traffic through and terminate VPN on the 7604, then you would need the SPA module.
Hope that answers your question.
