SETTING UP A PRIVATE CONNECTION USING TWO C891F-K9 IN TWO DIFF. LOCATIONS
okoroji80
Dear All.,
what is the best way to setup a secure private connection between two remote location without undermining the integrity of  domain data.
Scenario;
both sides have connection to the internet, site A has a Domain Controller with IP ; 172.16.1.99
The remote connection should be such that users at site B must be authenticated by the AD at site A before they can gain access to their PCs at site B
When logged in, users at site B are expected to have full access to the MS AD Server at site B .
What configuration is required on Cisco 891-k9 to be able to achieve the above solution
Site A
Inside nat
Outside nat
Window Server IP; 172.16.1.99
internal LAN IP ; 172.16.1.0
Outside IP; 41.x.y.z
Site B
inside nat
outside nat
internal LAN IP ; 192.168.10.0
outside IP; 212.X.Y.Z
Abaji Rawool
Level 3
Level 3
You can configure l2l VPN between two sites referring :http://www.cisco.com/c/en/us/support/docs/cloud-systems-management/configuration-professional/113337-ccp-vpn-routerA-routerB-config-00.html#CLI1
Abaji.
