simple lab site to site vpn does not work - pix to pix
anand.narine1
Hi all I have a home lab trying to setup a site to site vpn between 2 cisco pix 501 devices but it does not work. Can someone help, i have attached the followign run configs. thanks
PIX Version 6.2(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password NuLKvvWGg.x9HEKO encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname CiscoPix2
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list ping_acl permit icmp any any
access-list 90 permit ip 192.168.1.0 255.255.255.0 10.0.0.0 255.255.255.0
access-list 100 permit ip 192.168.1.0 255.255.255.0 10.0.0.0 255.255.255.0
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside 10.0.0.2 255.255.255.0
ip address inside 192.168.1.100 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
nat (inside) 0 access-list 90
access-group ping_acl in interface outside
access-group ping_acl in interface inside
route outside 0.0.0.0 0.0.0.0 10.0.0.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set strong esp-3des esp-sha-hmac
crypto map topix1 20 ipsec-isakmp
crypto map topix1 20 match address 100
crypto map topix1 20 set peer 10.0.0.1
crypto map topix1 20 set transform-set strong
crypto map topix1 interface outside
isakmp enable outside
isakmp key ******** address 10.0.0.1 netmask 255.255.255.255
isakmp policy 8 authentication pre-share
isakmp policy 8 encryption des
isakmp policy 8 hash sha
isakmp policy 8 group 1
isakmp policy 8 lifetime 86400
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:81f37c16401555abe7299b5a95e69d3d
: end
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 100full
passwd NuLKvvWGg.x9HEKO encrypted
hostname pixfirewall
fixup protocol dns maximum-length 512
fixup protocol sip udp 5060
fixup protocol tftp 69
names
access-list 90 permit ip 192.168.0.0 255.255.255.0 10.0.0.0 255.255.255.0
access-list 100 permit ip 192.168.0.0 255.255.255.0 10.0.0.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 10.0.0.1 255.255.255.0
ip address inside 192.168.0.100 255.255.255.0
pdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 10.0.0.2 1
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
http server enable
http 0.0.0.0 0.0.0.0 outside
floodguard enable
crypto map topix2 20 ipsec-isakmp
crypto map topix2 20 match address 100
crypto map topix2 20 set peer 10.0.0.2
crypto map topix2 20 set transform-set strong
crypto map topix2 interface outside
isakmp key ******** address 10.0.0.2 netmask 255.255.255.255
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:4558d14bca52c36021eeab79729ee63b
: end
Richard Burts
The first problem that I see is that the access list used to identify the VPN traffic permits traffic from your inside subnet to the outside subnet of the peer but not to the inside subnet of the peer.
Rick
Rick
Richard Burts
Rick
Rick
yes i just noticed that. changing that now. will let u know in a second
changed the access lists to the following and it works fine now. thanks
PIX Version 6.2(1)
hostname CiscoPix2
names
access-list 90 permit ip 192.168.1.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list 100 permit ip 192.168.1.0 255.255.255.0 192.168.0.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:2c2208bf5a797b9a2cadc82765993d2b
: end
PIX Version 6.3(3)
names
access-list 90 permit ip 192.168.0.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 100 permit ip 192.168.0.0 255.255.255.0 192.168.1.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:a6fc51fba2fb1f4c0d36ddc446413ea6
: end
I am glad that my suggestion pointed you in the right direction. Thanks for posting back to the forum and confirming that fixing this did allow the VPN to work.
Rick
Rick
