Site-to-Site packets ENCAP/DECAP with 50% packets loss problem
mysolutionscorp
Hello, Good Day!!
I have a problem in site-to-site VPN between Cisco 2801 router running (C2801-ADVENTERPRISEK9-M Version12.4(16))  and Cisco ASA Firewall 5515 running Version 8.6(1)2.
Problem ocurring when the phase 1 and 2  is completed and when i give the command "sh crypto ipsec sa" on cisco 2801 router it show all zeros in output: but on the other side its show packets encapsulate/decapsulate are fine on Cisco ASA.
I have matched the configuration its all fine on both end and also both endpoints are reaching with 50% packets loss.
Please assist me I am stuck with this problem :~
Cisco Router 2801Cisco firewall ASA
crypto isakmp policy 70
encr 3des
hash md5
authentication pre-share
group 2
lifetime 28800
phase 1:
crypto ikev1 policy 95
encryption 3des
hash md5
group 2
lifetime 28800
crypto isakmp key KEY_STRING address XXX.XXX.XXXX.XXXX
crypto ipsec transform-set TS_STRING esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto map KASBUAE 70 ipsec-isakmp
set peer XXX.XXX.XXX.XXX
set security-association lifetime seconds 28800
set transform-set TS_STRING
match address 110
crypto map outside_map 14 match address outside_cryptomap_13
crypto map outside_map 14 set peer XXX.XXX.XXX.XXX
crypto map outside_map 14 set ikev1 transform-set ESP-3DES-MD5
crypto map outside_map 14 set security-association lifetime seconds 28800
access-list 110 permit ip host 10.10.10.10 host 20.20.20.20
access-list 110 permit tcp host10.10.10.10 eq 1251 host 20.20.20.20
access-list 110 permit icmp host10.10.10.10 host 20.20.20.20
access-list outside_cryptomap_13 extended permit icmp object CISCO_ASA object CISCO_2811
___________________
access-list outside_cryptomap_13 extended permit tcp object CISCO_ASA object CISCO_2811
___________________
access-list outside_cryptomap_13 extended permit ip object
here:
CISCO_ASA = 20.20.20.20
CISCO_2811 = 10.10.10.10
protected vrf: (none)
   local  ident (addr/mask/prot/port): (10.142.56.105/255.255.255.255/6/1251)
   remote ident (addr/mask/prot/port): (10.0.31.6/255.255.255.255/6/0)
   current_peer 212.112.188.194 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: 202.44.92.18, remote crypto endpt.: 212.112.188.194
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet0/0
     current outbound spi: 0x0(0)
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
Thanks & Regards,
m.kafka
Level 4
Level 4
The ipsec sa is not established (inbound esp sas: empty)
Verify that your crypt acls are mirrored (unless you know exactly what you are doing)
If in doubt run a debug on phase (deb cryp ipsec) to see whats happening.
Rgds,
MiKa
PS: if you obfuscate addresses in your pseudo-config you should also obfuscate them in your debug output.
